R60 Towing Automatic on Tow Dolly
Old Aug 30, 2014 | 04:46 AM
hdzcar's Avatar
hdzcar
I just started towing my wife's automatic non 4wd behind our motorhome on a tow dolly. (Front wheels on dolly) and every time it throws a check engine light for the ABS. It clears after a few days the cars is driven but that seems weird with the ignition off while it's being towed.
Old Sep 4, 2014 | 01:09 PM
k2at11's Avatar
k2at11
I could be in error, but I thought I had read somewhere that one should not tow a countryman at all. One should use a flat bed truck and lift the whole car off the ground.
Old Sep 4, 2014 | 01:18 PM
k2at11's Avatar
k2at11
Old Sep 6, 2014 | 05:30 AM
chrunck's Avatar
chrunck
That's only true if you have the All4 (which the OP doesn't). You only have to get the drive wheels off the ground, however many of those you have.
Old Sep 6, 2014 | 09:58 AM
JABowders's Avatar
JABowders
Veteran: Army
Sounds like time for an experiment...
Try disconnecting the battery next time you tow it, and see if it throws the code when you reconnect it and drive off the the dolly.
Motor on!
elverado
Jan 18, 2022 02:51 AM
Apr 7, 2020 06:49 PM
krohm
Sep 28, 2015 12:16 PM
trexcookie
Sep 20, 2015 03:14 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
