R60 fog lamp bracket broke on my countryman
Old Aug 23, 2013 | 11:39 AM
raysmax's Avatar
raysmax
Does anyone know how to get in behind the fog lamp? Also the bracket that holds the fog lamp, I wonder if it can be ordered from the dealer. I can fix this myself if I can get behind there. The fog lamp still works.
Old Aug 23, 2013 | 01:11 PM
MIminiclubman's Avatar
MIminiclubman
You can get back there you need to search for and read the threads on removing the grill and then removing the bumper. You should just mount the new MINI Genuine DRL fog lamps while you have it apart.
Old Aug 23, 2013 | 02:13 PM
chrunck's Avatar
chrunck
Yeah I replaced my driver's side one after a bout of stupidity. I got the broken bracket off without removing the front apron, but there was no way to install the new one without taking it off. The dealer can get you just the bracket part (or pelican, or Sewell, or ecs, etc). I don't remember how much it was, but not too expensive.
Should be part number 63129807305.
Old Aug 23, 2013 | 08:57 PM
dpike's Avatar
dpike
i've read where a few people removed the headlights in order to change the foglights. maybe look into that rather than dropping the front bumper.
Old Aug 24, 2013 | 07:45 AM
chrunck's Avatar
chrunck
If the new fog lights mount in the existing bracket, you wouldn't have to remove the bumper. But it's next to impossible to get the bracket on without removing the bumper because there's a bolt 1/2" from the front crash bar. I was able to get it out with a low profile ratchet/chapman-type tool, but I could never get it started going back in because of the cramped space (could only get a couple fingers on it with one hand).
I only removed half of the fasteners and partially removed the bumper, so you don't have to take the whole thing off.
Old Aug 26, 2013 | 07:12 AM
Here it is for you guys. Part number 63129807305 . Same part number for the passenger and driver side.
Bracket For Front Fog Lamp - Priced Each
http://www.ecstuning.com/Search/SiteSearch/63129807305/
Aug 19, 2015 12:51 PM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
