R60 Dsc / dtc
Old Feb 28, 2013 | 10:19 AM
rmp's Avatar
rmp
Dsc / dtc
Lately I've been playing around with DSC / DTC in my ALL4 manual, and it seems that when I switch over to DTC, it seems as if it takes off from a stop a lot smoother, I'm not sure if it's a placebo or not, but I've tried it a few different times and it has felt smoother than with DSC on.
Is that normal, has anyone else noticed anything like that?
Could there be an issue? Mine is a 2011, so I'm concerned about the clutch, might just be imagining things because I am worried it might go out.
Old Feb 28, 2013 | 10:59 AM
bmwr606's Avatar
bmwr606
same here
the DSC seems to not allow any tire slip, it reduces power if any is detected
DTC will allow some tire slip before it intervenes and reduces power
if you are running all-season tires, you will have tire slip in snow so use DTC
i have studless ice and snow tires and either works fine for me unless i use full throttle, then DTC is the way to go
scott
Old Feb 28, 2013 | 11:50 AM
rmp's Avatar
rmp
I definitely noticed it in snow, I should have been more specific, but I've been noticing it on dry pavement, it seems to stutter a little with DSC on.
Old Feb 28, 2013 | 04:54 PM
Bakerbrdz's Avatar
Bakerbrdz
When it snowed here, I turn everything off to do donuts.
Old Feb 28, 2013 | 09:13 PM
Drnickm53's Avatar
Drnickm53
I do notice a bit better throttle response with the first one off. I think the computer has less work to do, less to monitor so it has less lag time going from your foot to dumping more fuel. Also, the idea that there is no power reducting for stopping wheel slip.
Old Mar 1, 2013 | 07:05 AM
chrunck's Avatar
chrunck
After reading this thread yesterday, I turned on DTC every time I drove the car, and it did seem easier to get going from a stop. I'll have to try it some more and figure out if it really was easier or if I was imagining it.
DrFraserCrane
Oct 7, 2015 04:04 AM
Samhillrocks
Sep 29, 2015 12:55 PM
Klenk
GP Talk
Sep 16, 2015 11:29 PM
