R60 Ebay roof rack
Old May 22, 2012 | 07:14 PM
bigdog100's Avatar
bigdog100
Ebay roof rack
Hi, anyone try this roof rack, does it fit tight?
http://www.ebay.com/itm/150811583815...S:1123&vxp=mtr
Old May 22, 2012 | 09:26 PM
MyroMini's Avatar
MyroMini
this looks a lot like the one I have for my Clubby (made by Thule europe). But the rail system on the Clubman vs the one on the Countryman is quite different. IIRC, the bars on the CM are flush-mounted to the roof, but are elevated for the Clubman. Maybe contact the seller. It does say it is Countryman compatible in their ad...
Old May 23, 2012 | 08:49 AM
bigdog100's Avatar
bigdog100
I did email them here is response:
Fitment : Universal Fit For Vehicles With An Existing Roof Side Rail System ( Please measure your vehicle Tower Distance Is Not Over 42 Inches Before Purchasing )
Install the cross bars onto your side bars is fast & easy. Each rubber coated foot grips onto the side bar & with a twist of a ****, the roof rack cross bar secures itself to your vehicle. Side bars need to have a clearance of 1¾" from the roof of the vehicle and also be 1¾" wide or less in order to securely attach the cross bars.
thanks,
proexhaust
Basically still does not answer the question
Old May 23, 2012 | 08:55 AM
MyroMini's Avatar
MyroMini
well, in a way, you have your answer
"Side bars need to have a clearance of 1¾" from the roof of the vehicle"
On your Countryman, do you have a space of 1¾" between roof and bottom of the roof rails?
I don't think so. Aren't the roof rails flush with the roof? Go to your car. Can you fit your fingers under the roof rail?
Old May 23, 2012 | 09:09 AM
bigdog100's Avatar
bigdog100
Ya on the inside it is only 1.5 clearance. Distance is 41"
Old May 23, 2012 | 10:10 AM
minie's Avatar
minie
from the picture i don't think it would work, as you have no space between our roof and the factory rail
Old May 23, 2012 | 10:08 PM
ozarkgolfer's Avatar
ozarkgolfer
The compatibility section of the auction shows:
This part is not compatible with 2011 Mini Cooper Countryman S ALL4
an there is no option to check for a 2012.
patsum
26
May 29, 2021 06:29 PM
techgearpro
Jul 23, 2019 07:09 PM
R60SX
Sep 23, 2015 09:01 AM
Gen1Parts
Sep 7, 2015 03:50 PM
schwac2
Sep 3, 2015 08:56 PM
