R60 Cool things i found.
I really like the adaptive xenons. An excellent choice, right up there with getting the manual transmission on my CM4.
But I also like the amber turn signals in back and the rear fog light arrangement available in Europe but not in the U.S.
Awesome! Thanks for posting that video! Definitely adding that when I order my CM.
I know I can open my sunroof & windows when walking up to the car by holding the un-lock button down on the remote...but is there a trick to re-closing windows/roof via my remote?
What I do now: get in, insert the remote in the dash, hit start/stop to activate electrics then hit the dash window switches and overhead roof switch.
Also, is there a one-touch open or close on the windows and/or roof? Haven't found it, maybe I've missed something...
only if you have the comfort access, if you do, you can close it all up using the physical key in the door handle by holding it after the door locks, otherwise... like in my case... i can only close it up from inside
[quote=alanbatchelor;3302868]
I know we all have problems with various things, mine is voice dialing, funny engine blip, connect cable and a few others things.
quote]
YES.. Funny engine blip is annoying as hell.. At least I know Im not crazy and Im not the only one it happens too.. Anyone else notice how hard it downshifts into 1st gear sometimes? Mine drops hard. Not always, but enough to notice and I'm not in sport mode..
YES to the connect cable.. Biggest piece of crap. Wont stay connected at all. And why is it 6 inches long? Really?
and I wish my Mini had the adaptive headlights.. My old BMW had them, it was nice..
quote]
I've seen a couple of people say that, and I really think its a case of wanting something you can't have (although I'm sure they would be easy enough to get), the US rear lights really look so much better, why would you want to add another color?
I prefer amber turn signals because there's less ambiguity and wish they were mandatory in the US. There's too many people that drive around with burnt out taillights, and sometimes you don't know if they have their blinker on or if they just have one functional taillight left. I don't really care what looks better.
I'm pretty sure it's because the AC actually uses Celsius and not Fahrenheit. If 64 is too cold, try putting it on 66 and turning on the recirculate feature. You get higher air flow that way, which should help.
The bright light on left at 44 second mark is the rear fog light. It's mandatory equipment in Europe. Some European cars offer them in the US although people here don't seem to understand they should only be used under greatly reduced visibility.
Generally, you only get one rear fog light and it replaces the back 'em up light. I believe what you are seeing here is first the fog light on the left, then the back up light on the right.
Correct. The typical rear fog light is only a single light located on the side of the car that is closest to the centerline of the roadway (side on which the driver sits). In the UK, the fog light would be on the right side of the rear and the backup light on the left. Ergo, the CM in the video is a left-hand drive model.
Sealy - Who expects a little more flexibility for $38K
Well, the center toggle between the window switches - - - if alll your doors are locked and you push it down, they all unlock. Or if they are unlocked and you push it down, they lock. Or if they are locked and you push it up, they unlock. Or if they are unlocked and you push it up, they lock.
Sealy - who really found that it doesn't matter which way you push the door lock switch.
