R60 Tiny Gas Tank
Old May 24, 2011 | 11:15 AM
  #26
tippykayak's Avatar
tippykayak
Good luck to you, sir. Our thoughts are with you.
Originally Posted by Miniblue2
Say you get a range of 300 miles and average 28.5 mpg. That suggests about 10.5 gallons of gas. It follows then that when the car thinks it is empty there may still be about 2 gallons of reserve.
Wish me luck as I'm going to test the theory. Computer indicates 106 miles to empty. I will be armed with my AAA card, cell phone and a gallon of gas. My goal is -50 miles on the computer and then I fill and FILL.
Bill
Old May 24, 2011 | 11:22 AM
  #27
MCS Fever's Avatar
MCS Fever
Originally Posted by Sealy
Check with Nissan. They're paying some Juke owners $400 for screwing up on tank size.
http://www.autotropolis.com/auto-new...ity-issue.html
If you think the price of gasoline is getting out of control, just talk to Nissan. Thanks to an oversight in the spec sheet for the 2011 Nissan Juke, the automaker is stroking checks to the tune of $285.71 per gallon to about 4,000 owners of its newest compact crossover.
A misprint in the Juke’s spec sheet listed all models having a 13.2-gallon fuel tank, but the all-wheel drive models actually had an 11.8-gallon fuel capacity.
To make up for this 1.4-gallon misrepresentation, Nissan is sending affected owners a check for $400 and an apology. That is quite a pricey gallon and a half of gasoline even considering the Juke only takes premium fuel........
They don't buy that car on it's good looks, do they........
Old May 24, 2011 | 02:07 PM
  #28
miniwpbear's Avatar
miniwpbear
I was wondering when this was going to be a thread. So far the small tank is my only complaint of the CM.
Tomorrow will mark 3 weeks with my CM and I have just hit 1200 miles and while this is a lot of miles in a short time, it still requires too many trips to the gas station when compared to my wife's 09 MCS.
Old May 24, 2011 | 02:19 PM
  #29
old81's Avatar
old81
M6
I have noticed it is a wee bit small, think roof rack with an auxiliary fuel tank with a gravity feed.
Really, I can live with it, but long trips I might take a gallon and put it on the roof rack (if I had one)....
Don
Old May 24, 2011 | 02:21 PM
  #30
Matt all4s's Avatar
Matt all4s
I keep all of my gas receipts and I have one for 11.6 gallons and one for 11.4. I think I always had one mark showing on the fuel gauge. I have never run the car down to zero miles to empty.
Old May 24, 2011 | 03:43 PM
  #31
tippykayak's Avatar
tippykayak
I put 10.7 in this afternoon with about 60 miles left on the calculator. I got just over 28 mpg on that tank (real world calculation, not on the heads up display). That means that if the tank is really 12.4 with no reserve, the miles left calculator is not kidding around. Anybody have a similar experience?
Old May 24, 2011 | 03:51 PM
  #32
mini_z's Avatar
mini_z
Smaller tank = Less at Pump. Its only $47 to fill up tank vs $75 etc. But its a pain to keep filling up every 3 days or so.
Old May 24, 2011 | 06:37 PM
  #33
ddbullard's Avatar
ddbullard
Mileage still seems to be improving slightly. Just got 343 miles on my last tank and put in 10.3 gallons to fill her back up. 33.3 MPG. This was 50/50 highway and backroads/city driving.
Old May 25, 2011 | 09:10 AM
  #34
mjgood's Avatar
mjgood
Originally Posted by Finner
I'm not a mechanic but I have always been advised not to let the gas tank run down too close to empty. Because over time, sediment or whatever pumped in with the gas when filling up sits at the bottom of the tank. When the tank is low on gas, some of that sediment can be pulled in to the gas line. So whether its my MINI, BMW or Audi, I usually fill up when around a quarter of a tank. I figure I would rather be safe than sorry and just avoid letting the tank run very close to empty.
Who knows what is at the bottom of the tank at the gas station, even a premium brand...if you happen to be getting gas when his tank is getting close to empty.
The tank draws from the bottom, so whatever sediment is there will get into the fuel line regardless of how much fuel is in the tank. The fuel filter will catch the sediment. As the tank gets low there is a greater amount of 'sloshing' which could stir loose some stubborn debris... If a car has a floating suction, this theory would apply, I don't know of any cars that work that way... BMW/MINI is very picky on what fuel you put in the car, check toptiergas.com, this is the approved fuel for your car, the others have too much ethanol which will void the warranty on your car.... If you stick with the approved fuel, you'll most likely never have any problems.
Old May 25, 2011 | 09:50 AM
  #35
tippykayak's Avatar
tippykayak
I'm not sure whether a dealer would be on firm legal ground to deny warranty based on an assumption about the fuel. I don't see anything specific about approved gas retailers in my warranty exclusions. Unless you said right out that you had put crap in, I don't see how they'd hold you to it.
Sure, you can test gas for octane and ethanol, but has anybody really had a warranty claim denied in this fashion?
Old May 25, 2011 | 11:00 AM
  #36
mjgood's Avatar
mjgood
The dealer gave us a hard time on my wife's 745, it was running real rough, first question was what fuel are you using? we told them were using supermarket fuel, they said the ethanol could be as high as 20% or higher and that would void the warranty if we continued.. within a couple of tanks the car was back to normal... the higher ethanol is why they have lower prices I guess..
After seeing what it did to her car I just stick to the name brands now... I'm not sure they can prove what fuel you're using, I just don't want to take the chance....
Old May 25, 2011 | 11:07 AM
  #37
mjgood's Avatar
mjgood
Just looked in the MINI owners manual... It says that fuel up to 10% will not void the warranty. It also recommends 91 octane but you can use 89... If I remember right my '05 MCS was 91 or higher, don't have car anymore..
again, unless you say something, It would be hard to prove....
Old May 25, 2011 | 06:08 PM
  #38
Miniblue2's Avatar
Miniblue2
Tiny tank and figuring how much further you can go.
I went to Houston this afternoon a 64 mile round trip. When I left the office the odometer read 212 and the computer indicated 96 more miles to empty. When I got to Houston, about 32 miles I still had 84 miles to empty. When I got back to the office odometer read 276 and miles to go was 60. According to MINI I used 36 miles worth of gas in 64 miles traveled.
Story here appears to be that I can't rely on the miles left for a real number. I'm not sure I will try for -50 after all. I will be cutting it close and noting how many miles I went and how much gas I got. The computer and how it works is a mystery to me. I am assuming it reads the tank level, knows how much gas is left and makes a calculation based on some mpg number it either has programmed or computes.
Does anyone know how it really works?
Thanks,
Bill
Old May 25, 2011 | 06:39 PM
  #39
MINItitan's Avatar
MINItitan
I don't have an online version of the manual to quote.... but I believe the computer uses something like the LAST 35 miles of driving to determine distance remaining....
Old May 25, 2011 | 08:12 PM
  #40
j_vincent's Avatar
j_vincent
The car has no idea what you are planning so it goes by what you've recently done:
Cruising range
Displays the estimated cruising range available with the remaining fuel. The range is calculated on the basis of the way the car has been driven over the last 18 miles/30 km and the amount of fuel currently in the tank.
If the range displayed is less than 30 miles/50 km, be sure to refuel; other- wise, engine functions are not guaranteed and damage could occur.
John
Old May 25, 2011 | 10:10 PM
  #41
DneprDave's Avatar
DneprDave
I have a Volvo, the fuel gage shows gallons left, rather than percentage. It is acurate! It shouldn't be difficult for MINI to do the same thing.
Dave
Old May 26, 2011 | 04:31 AM
  #42
mjgood's Avatar
mjgood
Dave
That would be nice option, to have the choice between gallons or range, the car certainly knows how many gallons are in it.. I have the MINI connected app on my iPhone, the car will speak how many gallons it has and the fuel level shown in gallons is displayed on the iPhone...
Old May 26, 2011 | 04:34 AM
  #43
yetti96's Avatar
yetti96
That would then mean a lawsuit for the gas provider as the sticker on the pump says can contain up to 10% any more than that would be illegal.
Old May 26, 2011 | 04:36 AM
  #44
yetti96's Avatar
yetti96
Thanks,
Bill
Just yesterday I got to 1 mile to empty and no candy corns were lit up but I would venture to say it would not go negative, just hover at 1 or 0. I left the house with 8 miles then got gas when it said 1 mile becasue it was the closest gas station.
Old May 26, 2011 | 05:00 AM
  #45
mjgood's Avatar
mjgood
I went back to the supermarket where we were getting the fuel, their pump actually said up to 15% ethanol.
I get fuel from Shell only, theirs says 10%...
Old May 26, 2011 | 05:06 AM
  #46
Miniblue2's Avatar
Miniblue2
When you filled up with 1 mile left, how much gas did the car take?
Thanks,
Bill
Old May 26, 2011 | 11:45 PM
  #47
guppybean's Avatar
guppybean
I filled up today when the mileage to empty said 6 miles. It took exactly 12 gal....i was starting to get a little worried as i was driving down I5...lol. The gas gauge still had one tick left on it.
Steve
Old May 27, 2011 | 04:10 AM
  #48
Miniblue2's Avatar
Miniblue2
Ok, so I chickened out. I filled with 5 miles left and it took 11.77 gallons. Indicated 28 mpg for the tank and 331 miles on the trip odometer. I'm going to assume a 12.5 gallon tank and the miles left is pretty accurate.
By the way, I left work for home with 30 miles remaining and got home (4.5 miles) with 11 miles remaining. Picked up the with and went straight for gas (1.3 miles) and got there with 5 miles indicated on the computer.
I think the moral hear is "Don't count on the miles remaining and pass a fill up when you have 30 miles indicated left in the tank and the next station is 15 miles down the road.
Bill
Old May 27, 2011 | 05:17 AM
  #49
Pennesseewassee's Avatar
Pennesseewassee
It is definitely a 12 gallon tank max - the good news is that my all around MPG with the Automatic All4 is 28 - not bad (and at the high end of the rating).
Old May 27, 2011 | 05:34 AM
  #50
tippykayak's Avatar
tippykayak
I put just over 12 in on my first tank with something like 15 miles left on the estimator, so it's definitely bigger than 12. I tend to believe that it's at least the 12.4 claimed on the spec sheet. If the estimator is really honest (and in every other car I've ever seen, there was still a small reserve after the estimator reached zero), then there's at least 12.4. There's no way of knowing there's a reserve beyond that without driving it to zero.
There's no way I'm running my brand new car to zero for a solely academic question, but if anybody wants to put two gallons in a gas can and drive their car to empty for research purposes, please post your results for the rest of us.
