R60 Countryman Photos
CM JCW looks great, made the pic bigger for you.
Wait until the new Clubman comes out, it will have a larger boot than the CM and more space inside, plus it'll be built on the UKL platform and will be a better car than the CM.
The F56 drives rings around a CM, so the Clubman should also be a blast to drive.
Aren't you always whinging on about the CM not being a real MINI due to it's size, the Clubman,(which I like BTW) will be even bigger than the current CM, and yes it may well be better but it probably should be since it will be re-designed
Don't feed the trolls.
It won't have the dynamic failings of a quasi SUV pretending to offer MINI levels handling and fun factor, I think it will be a brilliant vehicle and will point MINI back in the right direction, hopefully next time MINI offers an SUV they won't make a hash of it like they did with the CM.
As of January 2014, in the USA, the CM has sold more units in its 4 years of existence than the clubman has in its 6 years. Also, since the CM was introduced, sales of the clubman have DECLINED by 23%, 18.4%, 15.7% and 10.6% each year respectively. Oh, and worldwide MINI sales have INCREASED since the CM was introduced by 8.1%, 21.7%, 5.2% and 1.2% respectively, with 2013 being it's most successful year in history.
Yes... Total hash. Do your research, guy. The "fun factor" is a matter of opinion. But these are facts:
FYI I've never said the CM is a bad car, I've only ever said it's a bad MINI.
wow, BEE1, you are definitely unique, and that's what owning a Mini is all about.
I have never seen a graphic like that before.....very cool idea...
What size tires did you out on? How's the ride? Did you put a lift kit to fit them? I like the look. Contemplating on doing that to mine.
yokohama yk580 (235/55-18, overall diameter 28.18)
ride is pretty good no rubbing that i can see nor hear.
and yes, i have the 2in lift from cooper crap. but had to put spacers to fit the tire 20mm
so all in all my rim is 18in with 32 offset with the set up.
