Question on oil changes
Old Apr 11, 2007 | 07:07 AM
redmini04's Avatar
redmini04
Howdy folks.
Anyone know where to get the oil changed on my '04 S in the Strongsville, Ohio area? I don't want to drive clear up to Classic for this anymore. I checked Lube Stop and they are not set up to reset the "reminder milage" on the odometer.
Cheers,
Jim
Old Apr 11, 2007 | 09:11 AM
BWROOFCHEX's Avatar
BWROOFCHEX
Now you can have them do it.
reset procedure -
Maintenance Required Lamp/indicator:Service and Repair
Resetting the Service Interval Indicator
- the ignition key must be in the "0" (off) position
- press and hold the trip odometer reset button in the instrument cluster,and turn the ignition key to the "1" (accessory) position.
- keep the button pressed for approx. 5 SECONDS to change to the reset mode. The letters "RST" appear. While the display is flashing, press the button briefly to reset the service interval. The new interval will be displayed for 5 SECONDS.
- Release the button and turn ignition off.
This should work from 02 - 05.
Old Apr 11, 2007 | 10:10 AM
redmini04's Avatar
redmini04
Thanks for the info. I figured there must be an easy way to reset that thing.
Cheers,
Jim
silence2-38554
Nov 12, 2015 09:39 AM
patpatpat
Aug 27, 2015 07:51 AM
ShadyCoop
Aug 24, 2015 06:05 AM
elightbo
Aug 17, 2015 01:50 PM
Emnotek
Aug 13, 2015 05:47 PM
