Does the MINI motor use a throttle body?
Old Apr 7, 2006 | 02:21 AM
JATO's Avatar
JATO
I was reading some posts here and it appears the MINI uses a throtlle body injection system but I thought for sure I saw individual injectors. Do I misunderstand the whole setup? If the MINI uses throttle body, doesn't this make it harder to get it through the smog requirements?
Old Apr 7, 2006 | 04:24 AM
mdsbrain's Avatar
mdsbrain
I'm no engine expert but:
The MINI engine has a throttle body and each cylinder has its own injector.
Old Apr 7, 2006 | 05:53 AM
petecrosby's Avatar
petecrosby
Virtually all fuel injected cars have a throttle body, regardless of the type
of injection used. The throttle body houses the butterfly valve to control
the air intake (and is electrically controlled on the MINI). Fuel injection is,
I believe, into the intake manifold, and not direct injection (into the
cylinders).
Old Apr 7, 2006 | 07:20 AM
JATO's Avatar
JATO
cylinders).
I see, I always thought of the GM vehicles that used the one fuel injector that sat in place of the carburetor as a throttle body but what your saying makes sense. I have my terminology wrong.
Old Apr 7, 2006 | 08:54 AM
bobdobbs's Avatar
bobdobbs
Virtually all fuel injected cars have a throttle body, regardless of the type of injection used. .
The notable exception is the new BMW engines that use continuously variable valve lift to vary the amount of air entering the cylinders.
Valvetronic varies the timing and the lift of the intake valves. The Valvetronic system has a conventional intake cam, but it also uses a secondary eccentric shaft with a series of levers and roller followers, activated by a stepper motor. Based on signals formerly taken mechanically from the accelerator pedal, the stepper motor changes the phase of the eccentric cam, modifying the action of the intake valves.
http://www.bmwworld.com/technology/valvetronic.htm
Old Apr 7, 2006 | 10:02 AM
mielnicki's Avatar
mielnicki
TBI-Throttle Body Injection, the injector(s) is located in a central throttle body.
MPFI-Multiport Fuel Injection, multiple injectors usually but not always one per cylinder located along a fuel rail.
DFI-Direct Fuel Injection,Each cylinder has it's own injector firing directly into the cylinder.
Steve
Old Apr 7, 2006 | 10:09 AM
not-so-rednwhitecooper
TBI in a GM vehicle = A Rochester carb with a fuel injector dangling over the venturi's, lol
I love early 80's GM motors!!!
mdutton11
14
Oct 26, 2015 01:47 PM
quickquest88
Aug 8, 2015 08:45 PM
marendt428
Aug 8, 2015 04:44 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
