Mini Cooper s engine issues
Old Jan 11, 2024 | 05:22 AM
nielsmeijer's Avatar
nielsmeijer
Hi all! I am new here so let's introduce myself. My name is Niels and I am an 18 year-old who just bought his first car. it's a 2007 n14 Mini Cooper s. sadly it started acting up and doing some weird stuff. it all kinda started when the battery was flat. i ordered a new one but it took 3 months to get here. when I eventually got the battery, I installed it and fired up the car. at first it ran fine but after 5 - 10 seconds started to jumped shake around like crazy and then shut off with the car giving me half a check engine light. I must say it's worse when it's cold outside. but if I keep starting it and it gets warm, it idles fine. until I rev the car up, it'll rev uncontrollably and keeps floating. when I let go of the gas the engine turns off. I also can't see the coolant temp anymore (which I could see a few weeks ago). and changed it for a new one without any luck. it just says ***ºC. I went ahead and got an ISTA device and read the codes from the car. it had like 18 codes, but then cleared them all. there were 2 codes left after that: knock sensor and super knock. im thinking about the timing chain, tensioner, spark plugs, coil packs or the HPFP. I also have some videos from how the car acts. I do apologise for my English but i'm Duch. if you watch the video to the end you can see it does some weird things. it also sounds like a diesel engine or something. I really want it to work again. as I just got my license and now I can drive on my own.
Old Jan 11, 2024 | 12:26 PM
cooper48's Avatar
cooper48
I would lean toward an ignition problem like a bad coil pack because in your first video you have an obvious miss causing the engine to stumble badly and then stall. You should be receiving a misfire code from your OBD II reader. If it is a misfire code, try switching the identified cylinder coil pack to another cylinder and see if the OBD II code moves to that cylinder. That will identify a bad coil pack and that may be all you need to change. It's also possible that you have multiple bad coil packs. Good luck.
Old Jan 11, 2024 | 01:30 PM
nielsmeijer
hi! thanks for looking into my problem. I have read the car and it didn't give me misfire codes (what I thought was strange). the coils packs do look rusty or orange like. and I have no idea how old the spark plugs are. ill took into changing them, although I don't have the right tools to get the spark plugs removed. do you think this could be related to the timingchain? and does a misfire cause half an engine light to come on?
thanks
Old Jan 12, 2024 | 07:46 AM
cooper48's Avatar
cooper48
I would start with the least expensive repair. That would be your spark plugs but I doubt they are the problem. Before replacement, you might try removing and re-gapping the plugs to see if that makes a difference. If your engine skipped timing you would be experiencing much worse problems. i.e., a valve hitting a piston. I have an R53 so our engines are different. Hopefully, someone with a 2007 N14 will weigh in here with good advice.
Old Jan 15, 2024 | 01:02 AM
nielsmeijer
hi, I've changed the coil packs, but that doesn't make any difference. ive also bought new spark plugs but I still have to install them. im thinking its a hpfp related problem, because the symptoms line up with what I'm reading online. I see the prices range from €80 - €800 so that's a bit confusing. I don't have the right tools to replace the spark plugs yet.
MCS4life
Aug 26, 2023 08:22 AM
Dale_Cooper
Mar 13, 2020 10:58 PM
lai8869
Jul 13, 2019 12:08 AM
tlmease
Jan 20, 2016 02:58 PM
muidaq
R60/R61 Stock Problems/Issues
Jul 31, 2015 03:10 PM
