Hello from St. Louis
Old Jul 6, 2023 | 11:35 AM
Ferret18's Avatar
Ferret18
Hi - picked up a 2010 R56 non running for my daughter and I to repair and be her first car. It had 3 burnt valves which we've replaced. I have a few questions I'll post in the forums and see if we can get it running right.
Craig
Old Jul 7, 2023 | 10:00 AM
Hello and welcome, tons of info under the R56 section. I would caution on giving that type of MINI as a first car. These cars if are not maintained and serviced will have a ton of problems down the road. Gen 1 and Gen 3 MINIs not so much.
Think of MINIs as a classic car when they are used and not maintained year after year. Yes it can be fixed and I have done them but its will cost more then most domestic cars and euro cars. Just wanted to give you a heads up.
Old Jul 7, 2023 | 11:39 AM
garry sharp's Avatar
garry sharp
Welcome to the forum
Old Jul 9, 2023 | 05:25 AM
gauss66's Avatar
gauss66
Mr ECS brings up some good points on the Gen 2 - but it is not all doom in gloom. For a leave home college car, the frustration of being stranded will go up given you are not present. If she is living at home, I would not worry as much about it.
The potential flag I see from your post: Having 3 burnt could be a symptom of not changing the oil ( since it was 3 ) and other things that were not maintained .... or just a bad water pump. Fuel pressure and oil pressure are the weak parts of these engines ( I have replaced both pumps - as my mechanic did a version of shimming - he is an experienced vet guy ).
As for first gens, there is a bit of a survival bias here - a lot of the bad running ones have been weeded out.
However, the gen 2 will be fun to drive. BTW - if you have a base vs an S ( JCW ), then much of what I said you can ignore !
Old Jul 15, 2023 | 04:58 AM
WallaceTheobald's Avatar
WallaceTheobald
Welcome
Matteo Petrini
Apr 15, 2021 11:13 AM
Matteo Petrini
Apr 14, 2021 04:44 AM
wdh
Jan 23, 2015 07:27 AM
Gees
Dec 12, 2005 12:48 PM
