Not starting issues
Old Dec 31, 2019 | 11:28 AM
eclarke44's Avatar
eclarke44
Not starting issues
Hi, I have a 2009 hatchback. In our last big rainstorm the sunroof leaked and the fuse panel got wet. We did our our best to dry out the interior and panel, but then problems started. First the windshield wipers stopped working. Then the car would flash every conceivable symbol warning on start up. Then the next day it started dying, and finally stranded me on the side of the road. Took it home, made sure it was dry, changed a relay in the fuse box, nope. Read the codes and it came up with: a0b1,a0b3,a0b5,a0b6. So my husband thinks it’s electrical and suspects the CAS module. I’m wondering if some sort of relay to the gears is shorting or dead and the gear position sensor won’t let me start the car. We suspect there is a parasitic drain on the battery as it’s loosing charge just sitting in the driveway, unless we put it on the charger. Any ideas? I have an appt at a shop but we aren’t millionaires so any info would be much appreciated!!
trailrated
Dec 13, 2021 09:10 AM
msuspartan2009
Jan 21, 2011 09:27 AM
vizcarmb
May 10, 2010 01:46 PM
tickle
May 6, 2008 08:31 AM
