I am stuck
Old Aug 22, 2016 | 04:31 AM
Winston Lobegeier's Avatar
Winston Lobegeier
I am stuck
Hi Everyone,
I am new to this type of forum. I am a motor mechanic by trade but had not done a lot in the past 20 years. My daughter purchased a 2005 Mini Cooper S Auto (Chilli). Other than a regular service and replaced the cracked coolant expansion tank it has been a magic little machine. About a month ago she tied to start it and it would not start. All dash lights, headlights etc worked fine but would not crank over. Battery checked, good. Heard that starter motors can be an issue, removed it and had it checked. Thought it may have been the immobiliser, so took it out and had it reprogrammed. Also had a new key cut for it, so it was not a flat battery in the key. After the immobiliser was put back in the car started and did so for about 24hrs. Now it is doing the same again. All dash lights, head lights etc work but no start. When the key is turn on you can hear the fuel pump working. Had also heard that the starter relay could be an issue but not sure where it is located. There is 4 relays next to the engine ECM in the fuse box which I have swapped around but no change. Can anyone shed some light on what I have missed please? Thanks for you help.
Old Aug 23, 2016 | 07:33 AM
I would first scan the car and see whats going on. It will find more codes then the standard OBD 2 reader :
https://www.northamericanmotoring.co...d-q-and-a.html
Then check the Starter relay and all the wires from the battery to the alternator.
Fuse box diagram and locations
https://www.northamericanmotoring.co...nd-wiring.html
https://www.northamericanmotoring.co...rank-over.html
MidwayMountaineer
Jun 27, 2022 07:39 AM
rondelli
Jul 16, 2016 04:33 PM
moremini
Apr 20, 2016 07:08 AM
spikeyadrian
Mar 18, 2016 07:24 AM
normstangl
Aug 23, 2007 02:24 PM
