New MC Owner
Old May 28, 2015 | 04:56 AM
threeb's Avatar
threeb
New MC Owner
I recently just purchased a 2004 MC base with 49,000 miles on it. Absolutely love the car, but within 48 hours the a/c went out. I have ordered all the parts to repair (Compressor, condenser, expansion valve, drier, seals) after performing a complete diagnostics on the a/c. It appears the compressor clutch coil went out, but after cracking it open it was apparent the compressor also failed (Leaking oil) and the clutch was damaged. I decided to replace as much as I could since this will be my daughters car in a couple years. My issue is, when flushing the system can you flush the evaporator or do you need to remove the a/c lines to keep debris from passing through it?
Any help would be greatly appreciated.
Thanks----Rob
Old May 28, 2015 | 05:14 AM
JABowders's Avatar
JABowders
Veteran: Army
Welcome to the MINIacs!
OH, the dreaded AC service... I have rebuilt a few but when it comes to filling/charging the AC I take it to a shop that has the proper tools, where they can test and purge it prior to filling.
Best of luck.
Motor on!
Old May 28, 2015 | 06:59 AM
threeb's Avatar
threeb
Thanks for the help. It seems mechanics have different opinions on how to flush the system and what has to be put together in order to do it. I have an A/C mechanic who has all the tools to complete it, but he doesn't have the time right now to do the entire replacement. I already have everything out of the car, but just need to make sure before installing new parts, I don't have to perform a complete flush. Or if I do, what gets flushed. Seems odd you would flush new parts and possibly introduce debris into them and risk contamination or damage. I also can't seem to find step by step instructions on how to flush the system. Any help????
tacticalbacon02
NEO Miniacs (Mini NEO)
Oct 4, 2019 07:18 PM
jacobj
Tires, Wheels, & Brakes
Oct 4, 2015 11:49 AM
USA-RET
Sep 8, 2015 01:50 PM
OutMotoring
Sep 8, 2015 06:27 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
