Engine shutdown!!!!!
Old Jan 22, 2013 | 12:24 PM
chevycoop's Avatar
chevycoop
Hello I have a 02 cooper s the engine shuts down at 115 mph, it causes the engine light to come on and the engine misses very badly I have to pull over shut the car off and restart it after a minute then it runs fine but has a #4 cylinder misfire. How can I eliminate this problem???
Old Jan 22, 2013 | 12:50 PM
miles_miles7's Avatar
miles_miles7
Dont go past 114mph.
Old Jan 22, 2013 | 12:52 PM
gilmoregirls999's Avatar
gilmoregirls999
hahaha. Sounds like a governer.
Old Jan 22, 2013 | 01:13 PM
ZippyNH's Avatar
ZippyNH
Sounds like you need to find the missfire issue...but running the car at such a highload/high speed, could be a hotspot.....Just a guess, but on a 10 year old car, it might be time for a valvejob, and maybe some rings...
But a compression check, etc would be a good start! It would lead you in the right direction..of solving the misfire...
Good thing you are on a track going 115 MPH!! That would be one hell of a ticket!!
Old Jan 22, 2013 | 01:19 PM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Fuel pump inlet filter, inline fuel filter, fuel rail pressure/FPR valve. Cheaper things to check B 4 an engine tear down.
Old Jan 23, 2013 | 05:24 PM
chevycoop's Avatar
chevycoop
Thanks for the info/suggestions. I will check the easier things first.
Old Jan 23, 2013 | 05:38 PM
Braminator's Avatar
Braminator
LOL except it is much higher and would not cause a CEL.
Compression and leak down test would be the cheapest to start to narrow it down.
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
