Coolant leak, please help
Old Aug 28, 2012 | 01:21 PM
DJF 83's Avatar
DJF 83
Hello, brand new to the forum and looking for some advice. I have discovered that My 07 Mini Cooper S has a coolant leak. From what I have read already it seems to be the thermostat housing gasket.
Is this difficult to change on the 07?
Do I need to buy the entire housing ($109) or just the gasket ($ 6)
Please help!
Old Aug 29, 2012 | 01:31 PM
MiniMello's Avatar
MiniMello
i would say if its leaking the housing is bad but i never worked on the turbo models so im useless on how hard it would be, someone else will give you that direction. good luck and check the expansion tank while your at it where the cap is and see if its wet at the seam, mine is they all seem to leak there.
Old Aug 29, 2012 | 03:30 PM
DJF 83's Avatar
DJF 83
Thank you, I did check the expansion tank and no leak there. It seems that as it heats up the leak becomes worse and is somewhere lower down, like where the t-stat would be. I made an appointment at the dealership but need a loaner and earliest appointment is 9/12/12!! I'll keep refilling the expansion tank each day and hope it makes it to the 9/12. No overheating has occurred so I believe that I will be alright until then and go easy on it.
Old Sep 3, 2012 | 07:26 AM
alanwrench's Avatar
alanwrench
"Going easy"? Traffic in the summmer is not easy on an engine. Running A/C? More heat.
You may want to park that thing until you fix it. Renting a car for a few days is cheaper than repairing the damage to an overheated engine, towing, AND a rental car.
Also: driving around with coolant leaking onto the road makes it slick for the two wheelers of the world.
MTC anyway.
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
rikaro
Sep 21, 2015 06:57 AM
olson187
Sep 18, 2015 10:26 AM
mimaal
Sep 4, 2015 09:09 AM
