Break In Question
Old Jul 21, 2012 | 11:45 AM
Tarbot's Avatar
Tarbot
Break In Question
Should you refrain from using "Sport mode" during the break in period?
Old Jul 21, 2012 | 01:31 PM
bmwr606's Avatar
bmwr606
i had sport mode on as i left the dealer lot
also, don't be afraid to use full throttle, just don't exceed the 4,500 rpm limit
my salesperson said "drive it easy for 1200 miles" the mechanics said "drive it hard, but keep it under 4,500 rpm"
scott
Old Jul 21, 2012 | 02:01 PM
OceanMini2's Avatar
OceanMini2
scott
I have broken in several motors. What I do is go for a long drive (200-300 miles) on some back roads and run the car at an RPM for about 2 minutes than change the RPM (1200-4500). I run different gears at different RPMs as well. Never bog or over load the motor. I like to do an oil change at 500 miles. After 500 miles I pump the throttle slowly up and down for about 20 seconds then continue driving different RPMs for about 4 min intervals before pumping the throttle slowly again. At 1200 miles do a second oil change. Then start driving more normal but not hard. At 1500 miles start having some fun with RPMs over 4500.
Old Jul 21, 2012 | 02:07 PM
CR&PW&JB's Avatar
CR&PW&JB
Originally Posted by OceanMini2
I have broken several motors.
Well then.. I'll be sure not to do what you do!
Old Jul 21, 2012 | 02:16 PM
Tarbot's Avatar
Tarbot
Thanks all... had many new cars and different dealers (Saab900 turbo, RX7 GTU, Subaru WRX, multiple Jeeps...) tell me many different ways to break them in, but never for such a long mileage time frame. Looking forward to my MCSa in about three weeks! I drive my cars pretty hard and want to make sure I give it a good head start!
Old Jul 21, 2012 | 02:20 PM
OceanMini2's Avatar
OceanMini2
Broken in,,,
Old Jul 21, 2012 | 02:23 PM
mini rocket's Avatar
mini rocket
I've used the soft method and the hard method listed below. Which way you decide to go is up to you, just remember to change the oil a couple of times during the break in....
If you take the time to read this, I think it helps to understand that its all about the piston rings.
http://www.mototuneusa.com/break_in_secrets.htm
dropnstylez
Oct 29, 2015 08:57 AM
donniedarko
Oct 21, 2015 01:15 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 03:01 PM
Manny_cooper
Sep 3, 2015 05:48 AM
