Reverse or fog light??
Old Feb 14, 2012 | 08:15 AM
zamfield's Avatar
zamfield
I've got a bumper insert over a hole which I know is either for the rear fog or reverse light.
I've removed the insert and there is a plug on the wiring loom there, ready to plug something into it.
Left and Right of the loom goes off to the side markers on the wheel arches.
I'm in the US so it doesn't have a fog light switch or the light so I'm wondering is this left over from the reversing light?
Mine are built into the rear lights and are OEM so I'm confused?!
I'd like to remove the insert and make it an extra reversing light (If that's what it is) or maybe wire the fog light up, but I'd rather use the wiring that's there already.
Any ideas?
Old Feb 14, 2012 | 08:18 AM
daflake's Avatar
daflake
Fog... I have that option and it is available depending on the state.
Old Feb 14, 2012 | 08:43 AM
TimL's Avatar
TimL
Originally Posted by daflake
Fog....
+1
With the wiring in place, it's also a relatively easy retrofit (as I did).
You will need the fog light pack itself, a toggle bank that includes the switch for the rear fogs, and a trip to the dealer to update the software. That last part is the b!+@# cost-wise.
Old Feb 14, 2012 | 08:58 AM
zamfield's Avatar
zamfield
Cool! - Thanks for the info.
Old Feb 14, 2012 | 08:59 AM
zamfield's Avatar
zamfield
Just had another thought... I could mod a reversing light to a spot light....
Old Feb 14, 2012 | 09:39 AM
yetti96's Avatar
yetti96
'02-'04 it was a reverse light. '05-'06 it was an optional rear fog light.
Old Feb 14, 2012 | 09:59 AM
rkw's Avatar
rkw
You can use that wiring harness and make it operate as either an extra brake or extra reverse light with a simple mod: http://gominigo.com/BLK-MINI.html
Or do what I did: https://www.northamericanmotoring.co...d-extreme.html
Sep 28, 2021 01:16 PM
Aug 21, 2015 12:58 PM
Aug 21, 2015 12:50 PM
Aug 19, 2015 12:51 PM
