New guy - bought Mini for spouse
Old Aug 1, 2011 | 07:40 AM
Lbowout's Avatar
Lbowout
Greetings all - just bought my wife a 2005 Mini Cooper S convertible for our 23d anniversary. It only has 43k miles and drives like a top! We are really enjoying it.
First set of question:
1. Where can I find a detailed list of scheduled maintenance intervals other than in the manual? Looking for something online.
2. How do you service the convertible top? It seems to creak pretty loud while going up?
3. How do I determine if I have the CVT automatic transmission or not?
Thanks,
Jeff
Old Aug 1, 2011 | 12:53 PM
MiniBro's Avatar
MiniBro
Where are those pictures, brotha!
Old Aug 1, 2011 | 01:15 PM
amberback's Avatar
amberback
No S model had the CVT.
Old Aug 7, 2011 | 06:36 AM
Lbowout's Avatar
Lbowout
Thanks Mindy - that's a relief to know. Haven't heard good things about it.
Old Aug 7, 2011 | 06:40 AM
mrluckypa's Avatar
mrluckypa
detailed service intervals
go to the owners lounge on the miniusa website.
Old Aug 7, 2011 | 06:53 PM
PC CooperS's Avatar
PC CooperS
Copied this off this site, sorry but I don't have the original poster's name to give proper credit
Mini Maintenance Schedule
Every Week:
Wash and detail inside and out
(actually every 3 days on average)
Every 14 days:
Check oil level
Check antifreeze level
Brakes: check fluid level
Power steering: check fluid level
Wipers: check fluid levels
Every 30 days:
Check all lights and bulbs
Tires: check pressure and tread, reset tire monitor
Every 60 days:
Shocks: check for leaks
Shock tower mount area: check for distortion
Every 90 days:
Battery: check terminals and cables
Belt: check for loose or worn belt
Hoses: check for leaks or bulges
Brakes: check pads for wear
Wiper blades: check for wear
Wax exterior paint
Every 180 days:
Rotate ignition keys to keep both charged
Apply dialectric grease to both ends of all plug wires
Every 3500 miles:
Replace oil and filter
Check wheel bolt torques with torque wrench (88ft.lb)
Every 5000 miles:
Check spark plug torque with torque wrench (20ft.lb)
At Service Interval Indicator:
MINI Oil Service (Replace oil and filter)
Replace microfilter
Check brake pads with MINI tool, replace if needed
Grease wheel centering hubs
Clean brake pad contact points in calipers
Replace wiper blades
Check parking brake actuation, adjust if necessary
Reset Service Interval Indicator
Stamp warranty book pages 11 and 16.
MINI Inspection 1
MINI Inspection 2
Every year:
Rotate and balance tires
Wiper blades: replace
Pressure wash undercarriage
State inspection
Inspect entire body for rust
Every 2 years:
Replace brake fluid
Check AC refrigerant level and pressure
Every 30,000 miles:
Replace (JCW) air filter
Every 40,000 miles:
Replace spark plug wires
Every 60,000 miles:
Replace belt
Replace brake pads
Drain, flush, and refill power steering fluid
Every 100,000 miles:
Replace (JCW) spark plugs
Replace O2 sensors
Every 4 years:
Replace coolant
Replace hoses
Replace transmission fluid
arf88
May 31, 2016 03:07 PM
tr3y003
Oct 22, 2015 10:48 AM
Mini'mon
Aug 26, 2015 01:02 PM
cjsdad
Aug 11, 2015 08:46 AM
eliseo1981
Aug 6, 2015 05:00 AM
