tire pressure lite
Old Apr 30, 2011 | 07:24 AM
garadar's Avatar
garadar
tire pressure lite
will custom wheels cause tire pressure lite to stay on 04 mini and if it does is there any way to disable it THANKS!!!!
Old Apr 30, 2011 | 09:20 AM
rhawth99's Avatar
rhawth99
No, the '02-'06 MINIs use the ABS wheel speed detectors to determine low tire pressure. There are no sensors in the wheel itself so custom wheels are not a problem. Starting with the '07 models, MINI went to sensors in the wheels.
Old Apr 30, 2011 | 04:18 PM
quikmni's Avatar
quikmni
+1 on NO.
You can install aftermarket wheels on an 04 with no problems.
Sometimes after a wheel/tire install the light will come on because of the air pressure change or the tires not being filled equally. Just adjust the air pressure and reset the light and you should be good to go.
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
