newbie w/ belt squeal
Old Jul 18, 2008 | 10:19 PM
1mini/m8's Avatar
1mini/m8
What up minination? I am new to NAM. But I come to you all for help.
I have an 04 mcs and I had a 17% alta sc pulley installed with a 539 napa belt. Now whenever I start the car cold it squeals for about 5 mins. s#@t drives me nuts even with a magnaflow. My mechanic replaced the idler pulley, no luck. then he replaced the belt tensioner and a new 539, no luck. Now he ordered a new 17% pulley from alta thinking the machining on the pulley was off , awaiting part. I know this thread has been done before, but I need some IDEAS. All ideas and solutions welcome. thanks
Old Jul 19, 2008 | 08:16 AM
BBCooper's Avatar
BBCooper
U need a different belt
it is probably the belt.. Try a 060535 length belt and the squealling should stop ... The 539 belt is stock length and with the 17% pulley the tensioner cant get enough "grip" on the belt..
Hope that helps
BBCooper
Old Jul 20, 2008 | 08:46 PM
1mini/m8's Avatar
1mini/m8
THANKS BB I"LL TRY THAT SIZE & I HOPE IT WORKS CUZ THE SQUEALING IS EMBARASSING
Old Jul 20, 2008 | 08:54 PM
daemon2's Avatar
daemon2
It could also be an alignment issue with the pulley. Check for rubber in the bottom of the engine bay, this is also a good sign of a misaligned sc pulley.
Old Jul 21, 2008 | 07:53 PM
1mini/m8's Avatar
1mini/m8
THANKS
THANKS DAEMON, DID YOU HAVE THE SAME ISSUE WITH YOUR PULLEY?
scfiveo
Sep 27, 2019 02:27 PM
VanisleRyan
Sep 30, 2015 08:35 PM
fkrowland
Sep 30, 2015 10:30 AM
dragonby
Sep 25, 2015 08:10 PM
daviday
Sep 25, 2015 01:31 AM
