Engine heaters for outdoor minis
I get my new clubman s in about 3 weeks(just crossed the canal yesterday) My mini will be an outdoor car in the northwest where winter temps are often below zero. Are ther block or recirculating heaters available for minis?
Any info would be greatly appreciated.
Thanks,MINISV
Thanks,MINISV
block heaters
I am not clear on block heaters for clubmans, but I know that for the mini cooper s and standard there are absolutely no block heaters straightr from mini for 2004 and newer. Below 20C you should get some heating on that engine to reduce on wear and tear on the pistons. It is a real shame that there are not anymore products available to mini owners in the frigid north. Mini has truly crippled us without more heating options. You can look at Defa Heating, but I could never figure out how to buy their products. Indeed a disappointment! I bought a Canadian block heater off of minimania.com. I live in Fairbanks, Alaska with a 2003 mini s and around here we heat our cars religiously. I would advise on getting a heating patch on to your oil pan (even though you may be using synthetic oil), and whatever else you can do in the meantime. Keep that engine warm!!!
-Peter
illig.ak@gmail.com
-Peter
illig.ak@gmail.com
illig.ak
Should the "below 20C" be 20F?
20 deg. C, is 68 deg.F
The oil pan heater you suggested, and maybe a heat blanket would be options, I don't think a dipstick heater will make it. There are also heat blankets for the battery.
I could tell you about a friend that used to slide a lit hibachi under his dads car to warm the engine
, but there isn't enough clearance under a Mini.
It can get really cold in Minnesota.
when I lived in Wyoming I placed a shop light with a 60 watt bulb directly under the oil pan of my Toy PU when it got below O F. Worked pretty well, but then the truck was parked in an unheated garage.
Ive been wondering about block heaters as a possible solution for the cam chain tensioner cold start clatter issue that plagues so many 2nd gen cars.
In case someone is wondering why it is SO important to heat your engine below 20F, it is not because of start up issues. Minis will start well below zero, but the issue is piston wear and tear. The space between the moving piston and the shaft it rides in are incredibly small, and when the block gets cold these metals shrink just enough to where if the engine starts (which it will), these metals will rub against one another a few times until they warm up. It is simply bad overall for an engine over time.
09R56
Nov 16, 2022 10:49 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
calebmil
Aug 7, 2015 05:54 AM
