Tire Sizes?
Old Nov 27, 2007 | 09:12 PM
shalbern's Avatar
shalbern
Tire Sizes?
Hi there, I am a new member of this forum.
I have recently inherited a 03 MINI which uses 175/65R15 tires. Apparently this size is hard to find in my area. It has been suggested to me I use the 10mm wider 185/65R15 which is half an inch more in diameter then my stock tires or the 185/60R15 tire which is one quarter inch of less in diameter than stock.
Taking advantage of this forum's vast experience base, and possible clearance issues, which 185 size tire should I purchase?
Old Nov 27, 2007 | 10:16 PM
jw34's Avatar
jw34
I replaced my 175/65/15's with 195/60/15's. You should check out the tire forum and search through the posts. Lots of answers there.
Old Nov 27, 2007 | 10:51 PM
Eric_Rowland's Avatar
Eric_Rowland
The tire size calculator will help you here.
185/65 is 2.1% larger
185/60 is 0.9% smaller
195/60 is 1.1% larger
All are well within reasonable variation from stock. It comes down to what you want from the tires.
Larger will increase mileage slightly and reduce acceleration slightly
Smaller will decrease mileage slightly and increase acceleration slightly
(due to effective gearing)
The wider tire will reduce mileage slightly (more friction), but will give a wider contact patch.
Given that the MCS runs 195/55-16 or 205/45-17 stock, a wider tire won't be an issue with clearance.
Old Nov 28, 2007 | 05:47 AM
jw34's Avatar
jw34
Here's one:
http://www.miata.net/garage/tirecalc.html
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
Waszak
Oct 21, 2017 05:55 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
