:: OutMotoring :: Check Out This New Dash Mounted Digital Gauge!
Check this new Integrated Digital Gauge out!
Also includes OIL TEMP readings!
Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior.
Specifically designed to support the 2007+ R55,R56,R57,R58,R59 platforms. Reads all data directly including boost for boosted engines directly from the diagnostics port for fast plug and play install.
Plug and Play installQuick plug and play install with zero cutting required. All power, ground, and data points come directly from the diagnostics port connector.
Boost/Vacuum DisplayHigh resolution boost/vacuum display directly from factory sensors.
Multiple Gauge DisplaysBoost/Vac, Coolant Temp, Oil Temp, Intake Air Temp, EGT(not all models), Throttle Plate, Speed, RPM with Shift-light, Battery voltage, AFR, Oil Temp and more!
Peak Recall & Run Record Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux InputsIncludes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, display settings and more!
Aaron@OutMotoring "info@outmotoring.com"
865-223-6335
OutMotoring.com: Home of the finest MINI and Aston Martin Parts + Accessories.
Shop online at www.OutMotoring.com
Free Shipping on most orders over $195 Click HERE
865-223-6335
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
