View Poll Results: Your interest in potential brake upgrade types
Voters: 1016. You may not vote on this poll
Brake upgrade survey
Everyone,
Lately I've received a lot of interest from vendors in figuring out what type of brake kits people are interested in upgrading to. If you could take a second and cast your vote in the above survey I would greatly appreciate it. Here is some information on each of the following types of brakes:
Mark
- Stock rotors (I don't plan to or have no desire to upgrade)
- Larger solid rotors
- Drilled rotors
- Slotted rotors
- Wave rotors (Wave shaped edge which supposedly improves cooling and gives more leading edges for the brake pads to grip. To date only seen in some European magazines)
- Dilled and slotted rotors
Mark
i assume this is for rotors only?
my vote would go for lighter, larger, curved vane directional, 3 slot, floating rotors... all performance, no bling... :smile:
if we're talking calipers too, then 4 piston front, 2 piston rear, monobloc, with same brake bias as stock, lightweight... alcons pretty please?
Your request though, will be granted, except it wont be made by Alcon
Originally Posted by Docofmind
Why monobloc? 2 piece is actually stronger and more rigid. Brembo started using the 1 piece design because it was more cost effective.
Then between the two of you, I pretty much have exactly what you want....
Non mono block, quick change pads, (hot or cold) directional rotors, lighter, gas slotted, non floating, correctly biased, no twin pot rears (not needed) and when you fit even the larger rear rotor you're still way under what you'd thought you'd spend!
I can't believe you slept through all those other posts...lol.....somehow we didn't hook up!
simply for quick pad changes. i'm lazy and track prep is long enough... nevermind about having to swap pads at an enduro... hot brakes and all...
A simple bridge bolt across the top makes for easy pad changes. It also provides an even stiffer and more rigid chassis to minimize flex.
Click on this link for more detailed information.
http://http://wilwood.com/Products/C...4R14/index.asp
I have the Brembo GT brake kit in the front on my MINI and their rotors on the rear. They are slotted, not drilled. They do cost more than most kits, but I think the quality is tops! When those puppies warm up, just show me the dime and I'll stop on it. Time after time, all day long. No fade. I repeat - no fade - ever! Incredibly short stopping distance!
Brembos are the best ! so, there ya go! :smile:
Originally Posted by mferguson
Everyone,
Mark
- Drilled rotors
- Slotted rotors
Mark
I voted for the slotted rotors, only because you left out slotted & dimpled. I would not put any type of drilled rotors on my MINI. I have replaced the fronts with EBC's slotted & dimpled.
pjo
Originally Posted by CTMINI
Paddy,
Does that bronze sheen wear off the EBCs after you have stopped on them a few times?
I'm in the market for rotors like, real soon. Also - is it imperitive to replace your pads when you get new rotors if the pads are not old? (Think 3,500 miles.)
I have only replaced the front rotors and when I did, I also put new EBC Green Stuff pads on the front. On the rear, I replaced only the pads and then proceeded to bed-in the new parts. I did not replace the rear rotors as they only provide about 20% of the total braking force and for my application autocross & daily driver, it was not necessary.
If it was up to me, I would put new pads on with new rotors, that way everything is starting off from a known point. Just the way I look at it. When it comes times for new rotors, new pads will be installed at the same time.
paddy
Paddy,
