Suspension Suspension: Stock vs. FSD vs. B4 ??
Old 04-08-2016, 01:40 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
JIM_GRAHAM is offline
Visibly the upper mounts looked OK and were not bent, but the were 10 years old and have taken a beating, so I just went ahead and replaced them.
Here are the links to everything I bought:
http://www.ebay.com/itm/221899551238
http://www.ebay.com/itm/281915692183
http://www.ebay.com/itm/301184163298
http://www.ebay.com/itm/271828776047
http://www.ebay.com/itm/271938025316
With the stuff above, I replaced everything but the springs.
Let me know if you have any questions.
  #102
Old 04-08-2016, 06:26 AM
Steffen.Johnson's Avatar
Steffen.Johnson
Steffen.Johnson is offline
Thanks so much! Ill be taking a look and making a list.
  #103
Old 04-08-2016, 11:59 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Received 1,136 Likes on 891 Posts
I took my time and it was about an 6 hour job, stopping for lunch and taking a test ride after I did the rears (first). Some observations:
The front dust boots and bump stops were shot.
There was NO shrooming of the top mounts, but I replaced them anyways, as I had bought them just in case.
The rear bushings and stops were fine but just discolored and I replaced them just because.
I did the rears first to get warmed up, and then went for a test ride. They were easy. No noises or squeeks, success.
On the fronts I did not take apart the ball joints like some of the videos. I just removed the pinch bolts. The existing Strut fell right out. Getting the new ones in was a different story. Huge PITA. I had to actually assemble and drive the car (15 feet) to get the struts to fully seat. The new Strut assemblies seemed to be taller (New), requiring spring compressors to shorten them to get them back in. It might have been easier to take the ball joints off, but I got them in.
Two of the JCW Strut brace bolts broke and I had to get new ones. They are special sleeved bolts. Grrrr.
I could actually move the front strut pistons in/out with my hands and they were not generating much resistance. It's no wonder my teeth were rattling when I hit bumps.
The overall ride is much better. It does not absorb the extreme harsh stuff (sport springs?), but I was not expecting a magic carpet ride for $250 bucks.
I am pleased with the ride and even more pleased that there are no squeeks or noises and I got the job done right.
The top bolts on the front struts required an Allen wrench and a deep socket that I used an adjustable wrench on (Mcgyver). I broke the bolt loose while the strut was in the car rather than fight with it laying in the driveway.
Front sway bar bolts require a box wrench and Allen wrench.
My background is a "shade tree" mechanic and I was able to complete the job in the driveway with a 1.5 ton jack and stands, along with tools I have accumulated over the years. I took pictures before I dismantled things so I could refer to them if I had an "oh ****" moment. (I had a few).
I am happy with the results; however a neighbor thought there was a bar brawl with a few Navy sailers when he heard some screaming and lots of expletives coming from my driveway at times.
Have at it and share your experience!
On one of the DIY sites they show how to take a short section (~2 ft long) of 2x2, place it under the spring perch and along side of the shock tube and use a floor jack to compress the spring. I usually use some heavy duty duct tape to hold the 2x2 in place. This will allow you to remove steering knuckle from the shock. This way you don't have to remove the ball joint. To reassemble you put the shock up in place in the strut tower, install the nuts that hold the upper mount in place, put the 2x2 in place and again compress the spring. The steering knuckle can then be slid in place without jamming up.
  #104
Old 04-10-2016, 07:42 AM
Steffen.Johnson
In a past post someone had mentioned me needing to order the bump stops for the rear shocks as well but from the pics it looks like they come installed on the strut themselves, is that the case when you ordered them?
  #105
Old 04-10-2016, 04:23 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
My rear shocks came with bumpstops. The were shown in the picture on the site and I confirmed they were included.
  #106
Old 04-11-2016, 04:51 AM
Steffen.Johnson
Perfect! Thanks for looking. I added everything needed to my cart on ECS and it looks like 600 in chnage for struts, stops, bolts, etc. Does that sound about right?
  #107
Old 04-12-2016, 05:24 PM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I took the eBay route and bought all Lemforder parts from the lowest buy now vendors that totaled about $450 delivered.
  #108
Old 04-12-2016, 06:41 PM
gknorr's Avatar
gknorr
gknorr is offline
You can get the top rear bushing set for a little less on Amazon:
Amazon.com: Shock Mount Bushing: Automotive Amazon.com: Shock Mount Bushing: Automotive
Also, the pricing of the Bilstein touring class struts at Rockauto.com is incredible - $205 shipped for the whole set of 4 (search for "rockauto coupon" to get an extra 5% off).
Does anyone know if the FSD's come with any bump stops? Pretty cool that the rear Bilsteins already come with them, as that's another $30 or so you save going that route.
I'm still trying to decide between the Bilstein TCs and FSDs myself. The price difference is huge at about $400, but folks seem to really like the FSDs once they get them on. Jim, how would you say Bilstein's compare to the stock ones with lower mileage?
  #109
Old 04-13-2016, 02:22 AM
JIM_GRAHAM's Avatar
JIM_GRAHAM
I have never driven stock sport suspension "new" since I bought both of my Minis used at the point that the suspension was already pretty compromised. As I mentioned earlier, the B4s feel pretty good with Sport Springs. It is a firm ride that takes up some of the bumps, but still hits hard on the harsh stuff. It is not a plush ride, but one you can drive aggressive with on the street.
I could not really justify +$400 for FSD without ever driving a car with that exact setup to see what I was buying. It would need to be a dramatic difference to justify the cost and I had no comparison.
HTH
  #110
Old 04-13-2016, 03:50 AM
gknorr's Avatar
gknorr
gknorr is offline
That description definitely helps - thanks! I agree, for $400 extra, the difference should be significant.
  #111
Old 04-13-2016, 04:59 AM
Steffen.Johnson
Ok thanks, looks like I will have to do a little more shopping around.
  #112
Old 04-19-2016, 07:04 PM
Mini Mania's Avatar
Mini Mania is offline
Bilstein
Hi Steffen:
With this month's discount the Bilstein Touring Class go for $330.
http://new.minimania.com/part/NMS309...s-Gen1-R50-r53
Plus, here's an application guide that details other brands in addition to Bilstein.
http://new.minimania.com/Mini_Cooper...lication_Guide
Please let us know if we can help!
  #113
Old 04-22-2016, 05:26 AM
Steffen.Johnson
Originally Posted by Mini Mania
Hi Steffen:
Thanks I will check them out!
  #114
Old 04-23-2016, 10:16 PM
Racingguy04's Avatar
Racingguy04
Racingguy04 is offline
I installed Koni FSD's today and wow what a difference! my OEM shocks had 75,000 miles on them and the bumps were pretty jarring, now it rides like a Cadillac, if it handles as well as stock I'll be super pleased. It took me seven and a half hours (including a trip to harbor freight for an impact wrench) it was hard work, but doable and much better than having to pay a shop to do the work.
The one issue I had with my shocks is on the front, the bottom spring mounting plate (where you put the spring pad and then the spring) was loose on the shock, does anybody know if this is normal? I oriented it on the shock the same way as the OEM shock and I figured it would probably settle with the weight of the car on it but I thought it was weird.
  #115
Old 04-25-2016, 05:07 AM
Steffen.Johnson
Glad to hear you are linking the ride quality. Do you have more review notes as the everyday driving has occurred since install? Im just curious how you like the different road conditions on the FSDs?
  #116
Old 04-25-2016, 01:34 PM
Racingguy04
Well I have one day of driving on them and I generally like them; they're smooth on the road and good when I push them. Unfortunately the fronts are coming off today and going back to Koni. It turns out that the spring mounts/perches aren't supposed to be loose, and they've found several sets that are so they're going to warranty them when they have the problem fixed in a few weeks but the bad news is I have to pull of the FSD's and put the old delphi's back on til they come in.
  #117
Old 04-26-2016, 05:06 AM
Steffen.Johnson
BUMMER! Sorry to hear that but at least they are honoring the lifetime warranty. Hang in there your MINI will be back to good in no time.
  #118
Old 05-27-2016, 11:26 AM
Racingguy04
I finally got my replacement front shocks installed yesterday! I also put in new strut mounts, new sway bar links, new upper and lower spring pads (though the originals looked fine when I compared the two) new gaiters, and new lower control arm outer ball joints. I did reuse the bump stops, but they looked fine. I definitely like the ride of the FSD's and I'm hoping to get the car on the track in a couple of weeks to really check out the performance.
I haven't driven the b4's but the fsd's are much smoother than the oems, and it feels like cornering will be slightly better than oem. I think if you can score fsd's for $600 or less then they are worth it, especially if you can do the work yourself, and the work isn't that hard.
  #119
Old 05-27-2016, 02:31 PM
gknorr's Avatar
gknorr
gknorr is offline
I had to order a single front damper direct from Koni to complete a set, and it had this problem too. They sent me a new one quickly without any trouble. Glad it got sorted out before installing. Hoping to get the FSDs installed on mine soon.
  #120
Old 05-29-2016, 11:04 AM
Racingguy04
That is a bummer but yeah much better to realize it before you do the install. I honestly wasn't planning on doing the fronts since I had a bad experience doing it once before but the tears were so easy and I already had it on jack stands... Oh well I kind of enjoy doing suspension work, it's not too greasy and it's pretty easy to do as long as you take your time and pay attention to what you're doing.
  #121
Old 05-30-2016, 12:45 PM
Steffen.Johnson
Just picked my car up at the dealer. The suspension is going to hold off till I can figure out if I am going to be able to keep it or not. But ill keep you all posted!
  #122
Old 09-13-2016, 02:30 PM
TorchMINI's Avatar
TorchMINI
TorchMINI is offline
I am going to jump into this old thread in case anyone can help me figure out what to do. I have the 2nd Gen body on my 2008 Clubman. I got 75k and 7 years out of my OEM suspension until rattles developed and my indy garage told me that my shocks were all done. I bought KONI FSD for all 4 corners to start a new life for my Mini.
Now, just 1.5 years and 12,000 miles later, the KONIs are shot. Rattling like crazy and leaking fluid. The 'lifetime warranty' is not easy to claim: You get only 1/2 of the retail price back if you get them in advance, meaning you keep driving your car, which I must.
Do KONIs last longer than 2 years generally? I drive softly on pretty good roads. Would another system last longer?
I can't afford to do this again on my tiny fixed retirement income. it's a quite unexpected expense after the big Koni investment last year.
Maybe I'll go for the 1/2 of retail back, but then I'd need to order new Konis now and trust that they'd find my other pair defective.
I'm hoping someone has an idea or perspective to help me make a decision to go on from here. The Konis felt great while they lasted...
  #123
Old 09-13-2016, 02:41 PM
haygood's Avatar
haygood
haygood is offline
Koni FSD
Where are your original shocks? If you have a mini shop nearby, maybe they could loan you some takeoffs. Half retail is absurd. Do what you need to to get it all back.
I have probably 30,000 miles on my FSD's and no problems. I would say our roads are moderately good and the car gets driven pretty hard.
I have my takeoffs from my R52. Let me know where you are if you want to try to use them.
  #124
Old 09-13-2016, 06:10 PM
gknorr's Avatar
gknorr
gknorr is offline
I've had FSDs on my other car ('08 Mazda 3) for over 4 years and about 50K miles with no problems.
If your FSD's are leaking, they will definitely be warrantied. Koni is good about honoring their warranty. I once ordered a shock from them that arrived with the spring plate loose, and they sent me another one and gave me a label for return shipping. So you'll pay half up front and then be refunded once they get your leaking struts. You'll have to check with them and see if the shipping is covered too.
Are you using lowering springs? I know that can shorten the life of the FSDs since they're meant for stock springs.
  #125
Old 09-20-2016, 03:39 AM
Steffen.Johnson
Like he said above. If you use lowering springs you will void the warranty as well. They might think you used those. I have heard nothing but good things about the folks over at Koni
Quick Reply: Suspension Suspension: Stock vs. FSD vs. B4 ??
