Driving with Broken Dipstick
Old 07-05-2015, 06:54 PM
boostedhaze's Avatar
boostedhaze
boostedhaze is offline
When I purchased my 05' MCS about three weeks ago I discovered that the dipstick was broken. I then went to Autozone and put a new OEM dipstick on order. Today (Less than two weeks after I bought the part) I discovered that the dipstick was broken in three places, and that the bottom third was stuck in the tube. Keep in mind that I put oil on the dipstick and tip and the O-rings before I installed it, and that I was very gentle. My question is, is it safe to drive? I was planning on doing a bunch of front end maintenance (SC Oil Change, Pulley Swap, Ect.) and upgrades within about two weeks but I could have the parts here for next weekend. My question is, is it safe to drive the car for the next week before I can take off the dipstick tube and take out the broken off piece?
Old 07-05-2015, 08:37 PM
David.R53's Avatar
David.R53
David.R53 is offline
You are a taking a chance.
I've had the pan off - it's not a bad job. Remove lower motor mount and the AC compressor mounts, the big bolts going into the tranny then the mess of little bolts. You would need a new gasket.
Anyway, the tube ends 2-3 inches above the bottom of the pan. If you think the broken piece is 6 inches than it should stay put. If it's more like 4 inches, then I'd guess it could wiggle free and could get into something.
The oil pump pickup has a fine screen on it, so don't worry about that.
But, it could get tangled or jammed into the crank somehow.
Old 07-05-2015, 08:43 PM
boostedhaze
I will measure how it broke off tomorrow, maybe I need to put an oil pan gasket on order depending in the results.
Old 07-06-2015, 11:19 AM
CravenSpeed's Avatar
CravenSpeed
CravenSpeed is offline
Vendor
Sorry to hear about that. Hopefully it broke because the previous owner checked the oil as frequently as they should have been.
Old 07-06-2015, 03:40 PM
boostedhaze
Oh I should have made it more clear in my original post, the dipstick that broke again was the one I just bought two weeks ago.
Old 07-06-2015, 09:03 PM
David.R53's Avatar
David.R53
The new one breaking alarms me. Was it a new dealer part? Maybe the dipstick tube has been damaged or crimped. Worth checking carefully. Probably used ones are available for a reasonable price from a wrecker or Way Motor works (he stocks some used parts).
Old 07-06-2015, 11:20 PM
Stinch's Avatar
Stinch
Stinch is offline
The OEM stick isn't a good design. Found mine cracked last month and while expensive, bought a Cravenspeed dip stick. Don't have to deal with that issue anymore.
Old 07-07-2015, 03:21 PM
David.R53's Avatar
David.R53
I understand a bad design causing a dipstick to break after 5 or 10 years - still entirely unacceptable - but 2 weeks? It seems like something else is going on - maybe a cheap aftermarket unit or a damaged guide tube or ??
Old 07-07-2015, 03:26 PM
boostedhaze
I will take a closer look at the guide tube, but it was smooth going in and doesn't appear to be bent. The replacement from autozone wasn't OEM BMW, of course I found that out after I had paid for it. The person on the phone said it would be OEM, and the one I got was from some no name brand.
Old 07-07-2015, 03:38 PM
David.R53's Avatar
David.R53
Old 07-07-2015, 03:51 PM
David.R53's Avatar
David.R53
Hope you can appreciate a little humor.
Wanted to point out this guy had a method to get his out with a modified grabber tool.
http://www.mini2.com/forum/first-generation-faults-fixes/172232-how-can-i-get-my-broken-dip-stick-out-no-rude-comments.html#/forumsite/20499/topics/172232
Old 07-11-2015, 08:18 AM
boostedhaze
I tried the grabber tool method at first but it was too far in there. Managed to get it out without dropping the oil pan since I was already doing supercharger service and took the dipstick tube out. There was just enough snapped off to rest on the bottom of the oil pan and not have it poke out of the hole, just ended up grabbing it with some needle nose. I have the cravenspeed dipstick waiting to go in so that this won't be an issue in the future.
Old 07-11-2015, 08:30 AM
David.R53's Avatar
David.R53
Glad it all worked out.
09R56
11-16-2022 10:49 AM
lotuseyes
08-18-2015 12:07 PM
elightbo
08-17-2015 01:50 PM
tag1260
08-10-2015 10:41 AM
pvtryan478
08-09-2015 12:24 PM
Quick Reply: Driving with Broken Dipstick
