power window issue, not the usual one.
Hi all, new user here. I have been using some DIY guides from this forum and they are useful. Thank you.
I now have a passenger side window on my R53 that is not moving. It is not fixed by hitting the door panel. I confirmed there is 11.5V at the motor connector. The voltage reversed polarity when I flipped the switch up and down. But it won't drive the motor even when I just connected a new motor held in my hand. If I connect the motor to the driver side connector then it would correctly turn both ways. No blown fuse.
Since the current came through the control module, my guess is that the control module somehow does not allow enough current to pass through. Does anyone have any other theories? TIA.
07-16-2020 12:54 PM
silence2-38554
98
09-21-2016 02:52 PM
12-23-2015 10:36 AM
