Missing f30 fuse... what exactly does it do?
So, after having a headlight washer nozzle break, decided to replace it and pull the headlight washer fuse to save anymore $80 repairs for a $5 trim piece, only to find an empty spot in my fuse box where a fuse "should" be, and hasn't been there since I purchased the car apparently.
All I can find on the web is that it is f30, an "instrument cluster" fuse, but as far as i can tell everything on my instrument cluster is working fine. Any electricians around that can explain if it is normal to be missing this fuse? I'm hopeful that it is just a chronos/nav package related fuse, and the standard packages just don't use it, but the panel diagram shows a fuse type/image for it so figured I would double check. In any case, I am a bit weary about putting a new fuse in, as I tend to follow the "don't fix what isn't broken" mentality.
F55/F56 Switched to GTI, miss the Mini!
BackroadRunner
09-29-2015 08:06 PM
