08 MCS N14 - Remove only Engine ?
Old 10-21-2014, 09:39 PM
PudgyMech's Avatar
PudgyMech
PudgyMech is offline
Can the N14 engine be removed from the R56 without removing the transmission?
PudgyMech
Old 10-22-2014, 05:31 AM
v10climber's Avatar
v10climber
v10climber is offline
You can't really remove just the engine. How are you planning on getting the engine out? Lifting out the top?
If you tried really hard it might be possible. The problem is there are only two motor mounts really holding the engine in the car. The one on the passenger side and the one on the drivers side bolted to the transmission. If you want to pull the engine you would still have to disconnect the transmission-side motor mount to give you enough room to separate the motor/trans to clear the trans input shaft. And honestly if you're at that point the only thing holding the trans in the car is the shift cables and the axles. The shift cables are super easy to remove and the axles aren't hard either. Just pop the outer ball joint to give you room to move the knuckle and then pop the axles out of the trans. You don't have to remove the axles from the car completely so you can keep the axle nut torqued. The passenger side axle has a bearing that bolts to the engine block you're going to have to unbolt anyways so the passenger side axle is also easy to remove from the trans.
Old 10-22-2014, 08:06 AM
PudgyMech's Avatar
PudgyMech
Thanks for the rundown. That sounds easy enough. I thought I would have to completely remove the axles. Time to go get a crane to lift the engine/trans.
PudgyMech
Old 10-22-2014, 10:34 AM
afadeev's Avatar
afadeev
afadeev is offline
Originally Posted by PudgyMech
Originally Posted by [URL="https://www.northamericanmotoring.com/forums/members/136578-v10climber.html"
v10climber[/URL]]You can't really remove just the engine. How are you planning on getting the engine out? Lifting out the top?
PudgyMech
+1 on pulling the tranny with the engine - delta effort is minimal, and you can properly service the transmission "while you are at it".
BTDT this spring, when I was swapping my N14 engines. A fairly straight forward job - just label all the electrical connections and coolant lines to minimize confusion during re-assembly.
Pics in my album.
Semi-detailed writeup elsewhere in this forum.
Feel free to PM if you have any Qs.
a
Kimolaoha
07-05-2023 01:04 PM
07-16-2020 12:54 PM
Zettinger
08-25-2015 04:04 PM
Getrieben
08-15-2015 09:09 PM
minipopkart
08-13-2015 05:22 AM
Quick Reply: 08 MCS N14 - Remove only Engine ?
