Carnage - The aftermath of a TOB gone IED
Old 04-25-2012, 07:35 AM
Carmichael's Avatar
Carmichael
Carmichael is offline
My car had 82k on her before I started to feel a vibration in the clutch pedal. These were the symptoms leading to the throwout bearing explosion (there's no other word for it):
- Vibrating clutch pedal
- "Scraping" noise under acceleration
- Inconsistent pedal feel (I think this was more related to the dead clutch slave )
I should also add at this point that my dual-mass flywheel seems okay ... But there is a possibility it was going bad (which explains the clutch pedal vibration). The clutch, while worn, also looked to be okay. The wear on the disc seemed normal.
I decided to just replace the whole thing with an Exedy flywheel and clutch kit. Here are some pictures of this past weekend's tear-down.
Picture 1 - Pulled the transmission out of the car and was greeted by a mangled TOB. Note the ball bearings concentrated on one side of the bearing! The metal piece and rivets holding the sleeve onto the bearing must have just gone to pieces. By doing so, shrapnel was bounced around the bellhousing, leaving everything in it looking like it was shot by a 12 gauge. Some of the bellhousing support ribs were chipped off as well. I had a pile of metal sitting at the bottom of the bellhousing.
Picture 2 - This, however caught my eye ... Was this just a deep gouge, or did something actually pierce the bellhousing?
Picture 3 - Separation of the gear case to install an LSD confirmed that whatever flew off the TOB assembly punched right through the diff housing and hit the factory open diff! No wonder I was getting a transmission oil leak!
More pictures as the story develops.
Attached Thumbnails Carnage - The aftermath of a TOB gone IED-20120421_163527.jpg   Carnage - The aftermath of a TOB gone IED-20120421_163541.jpg   Carnage - The aftermath of a TOB gone IED-20120421_175831.jpg
Old 04-25-2012, 08:06 AM
MaxMCS's Avatar
MaxMCS
MaxMCS is offline
YIKES!
I had a similar situation happen to me- I was doing 70 on I-95, and there was just this deafening explosion followed by a complete loss of power. It's a terrifying experience!
Best of luck with the repairs & rebuild. The LSD will be fun!
Old 04-25-2012, 09:20 AM
Carmichael's Avatar
Carmichael
Ugh. Having this happen on the highway sounds dangerous. I feared being stranded miles from home, so I'd left the car at my parents' place in the suburbs to work on it at a future date and explicitly told them NOT to drive it. Turns out my brother took it out to pick up his girlfriend and the TOB flew apart a half mile away from my parents' house. He limped it home and denies any wrongdoing. I should have just kept the damn keys ...
So, aside from plans to go medieval on my sibling, I have to install my clutch/flywheel kit.
Here's what the old clutch looked like:
Thanks to some impromptu shot-peening of the pressure plate, the torx-head pressure plate bolts were completely rounded off. Solution: get out the grinder, and off with their heads!
The funny thing is, with the bolt heads cut and the pressure plate off, the bolt stems threaded out of the flywheel with no effort at all.
Oh, the joys of MINI ownership!
Old 04-25-2012, 10:45 AM
ra2fanatic's Avatar
ra2fanatic
ra2fanatic is offline
wow sorry to hear all this! at least it's cool that you're diy'in it and not having another shop perform the work for you $$$$
Old 05-01-2012, 09:23 PM
Evasive's Avatar
Evasive
Evasive is offline
Really need to quit procrastinating and order a new clutch kit. Thinking I'll start mine next week. The idea of my TOB exploding and putting a hole in my transfer case scares the bejesus out of me.
Old 05-02-2012, 07:37 AM
Carmichael's Avatar
Carmichael
Here's what the bearing actually looked like when I pulled the transmission.
I've never seen anything like this. It's a good thing the bearing stayed in (mostly) one piece, though. I can't imagine what would have happened if the ball bearings actually flew out of there at 7000 RPM.
As an update, one of my father's friends has a TIG welder, thus, he patched up the hole in the diff housing for free (I apparently owe him a case of Hoegaarden for that ...). I cleaned up the weld, and made sure everything was right (even cleaned up some of the casting flash inside the transmission case). Just waiting on a new transmission input shaft seal (~$13 without shipping from MINI Peabody in MA). Might as well put a new one in since my throwout bearing guide tube was heavily scored and had heat marks from when my brother rode the clutch to get the car back on the driveway. That's getting replaced as well.
It's finals week for me, so like many law school students, I'm living underneath a stack of books, getting a nice tan from my computer screen courtesy of Westlaw. It's a miracle my boss allowed me some days off to study, but this also means I won't be working on the car for the next two weeks or so. That also means I'm missing out on the first few events this autocross season ...
Attached Thumbnails Carnage - The aftermath of a TOB gone IED-20120421_180018.jpg
Old 05-03-2012, 07:23 AM
Gamm's Avatar
Gamm
Gamm is offline
Aaaahhh... Good old memories.
Here's how mine looked like;
Old 05-03-2012, 04:45 PM
Carmichael's Avatar
Carmichael
FFFFFFFFFFFFFFFFFFFFFFFFFFUU--
Jeez, I would imagine a hole that massive would require a new bellhousing. How on earth did you fix that (if you didn't chuck the bellhousing into the dumpster first)?
Here are some pictures from last weekend.
I may have mentioned this before, but since the transmission gear case needed to be pulled apart to fix the hole left behind by the TOB, I decided to throw in a limited slip differential. I opted to order and rebuild an OBX helical unit, as so many have done before. Here's the final product of about a day's work sanding away burrs and sharp edges and polishing load-bearing surfaces.
Excuse the messy workbench ... My father and I are planning on building a bigger one this summer.
I stole the "Cars" baggies from my cousins. It's imperative I keep all those nuts and bolts in one place!
I had to use a long 3/8 extension to keep the belleville springs aligned. This didn't work out very well, so I used the handle of a cheap 3/8 drive ratchet. It fit snugly and kept the bellevilles aligned as I torqued down the diff.
Proper arrangement of the bellevilles per Rich Bryant's suggestion.
After giving each part a blast of brake cleaner and compressed air to clean it all up, I lubed each part with some Royal Purple (I have two quarts of Redline MTL ready to go in after break in. I had some extra Royal Purple laying around from the last time I did a transmission flush), put blue loctite on the new bolts, torqued each of them to 32 ft/lbs, and pressed the Timken bearings on (with my new harbor freight shop press! ).
So the diff's ready for the car, now I've got to put it in the transmission, replace the input shaft seal, throw it all back together and put it back in the car.
... Oh right, finals.
Old 05-03-2012, 07:34 PM
Evasive's Avatar
Evasive
Evasive is offline
Nice.
Your post was the push I needed to take care of my TOB so I ordered my clutch kit from Way today. Unfortunately, their entire shop is playing at the dragon instead of shipping my orders like all good shops should, so I'll be delayed in putting things back together. Tear down begins this Sunday after the monthly car show here in Colorado Springs. Fun times ahead...
Old 05-03-2012, 11:25 PM
Gamm's Avatar
Gamm
Gamm is offline
I ended up replacing the whole gearbox. There was no way this could have been repaired decently enough.
Ah wel...
Old 05-04-2012, 12:47 PM
Carmichael's Avatar
Carmichael
Originally Posted by Evasive
Nice.
Did you order the Valeo kit? I went with Exedy, based on the other clutch jobs I've done in the past. The last time I put an Exedy OEM clutch in a car, it was my brother's turbocharged Miata.
We threw together a turbo "kit" using my OEM TD04H-14B turbo from my AWD Talon, a Megan Racing manifold, Paxton FMU and exhaust tubing (it was around ~$800 total). At 10 PSI, the car was fast enough to waste my buddy's '05 WRX with bolt-ons, and the clutch held together, even when the car was making roughly double it's stock output and used for drifting (my brother was an unabashed clutch kicker).
I've heard good things about the Valeo kit, but not enough on the Exedy. I got mine for $317 shipped from Amazon, and it was shipped directly from an Exedy supplier in the US, so it was a lot cheaper.
I'm definitely taking my time on this project due to personal commitments (not to mention I'm tackling other things like the supercharger PTO drive box, water pump, timing chain tensioner, oil pressure gauge sending unit, power steering hose replacement and power steering fluid flush, etc. ), but there's no reason it couldn't be done in the span of a weekend with the help of an assistant.
Old 05-04-2012, 02:35 PM
Evasive's Avatar
Evasive
Evasive is offline
I went with the Valeo kit. $317 shipped is an amazing price though but I opted for Valeo since there was a lot of good feedback from this site about this kit. Does the Exedy come with a new flywheel as well?
Old 05-04-2012, 05:49 PM
Carmichael's Avatar
Carmichael
Yep. I don't know how much lighter it is compared to the stock one, but I've seen some sellers advertise the flywheel as being chro-moly steel. Seems like a regular old steel one to me. I'll try weighing it using the weigh-yourself-then-yourself-holding-the-item method. I've had a chro-moly flywheel on my Talon before (JUN Auto), and it lasted 15,000 miles before it warped. I replaced it with a Fidanza 8 lb., and boy, is the car a pain to drive around a parking lot.
I used the money I saved to buy a transmission jack, though the transmission itself is light enough to use the "bench press" method to get it back on the engine, I wouldn't recommend it ... I have a scar on my eyebrow from when that went wrong ...
Old 05-04-2012, 06:26 PM
Evasive's Avatar
Evasive
Evasive is offline
I'm not even going to try the bench press method. I'll either bum a transmission jack or pick one up from harbor freight.
Old 05-04-2012, 07:30 PM
miniconcarne's Avatar
miniconcarne
miniconcarne is offline
Hey Mark, if you need a hand with this let me know..gonna need to learn how to do my own clutch soon!
Bryan
Old 05-04-2012, 08:09 PM
Evasive's Avatar
Evasive
Evasive is offline
Bryan
Sounds good man. Will definitely let you know when the parts are coming in. Hope to see you at the First and Main car show tomorrow.
Old 05-04-2012, 08:18 PM
miniconcarne
MINI is DOA, so I'll probably pass this time.
Old 05-04-2012, 11:00 PM
Carmichael's Avatar
Carmichael
Ah, that was back in high school. I was helping my father do the clutch on his old '93 Accord LX coupe, and it was time to put the tranny and engine back together from underneath the car. Long story short, my hands slipped, and I ended up with a bruise on my chest and a cut on my face! ... I did more idiotic things back then, but that's pretty high on the list of "things that could have permanently deformed and/or killed me."
The 450 lb. capacity Harbor Freight tranny jack worked really well for me. The ratchet strap that came with it is pretty useless (it wraps widthwise), but I was able to hold the transmission securely to the jack using an extra ratchet strap positioned lengthwise underneath the tray. It's a screw-type jack, so I was able to use my 1/2" impact gun to raise/lower it quickly.
I think I picked it up for $80 with one of those "save an extra 20%" coupons for Inside Track members.
Old 05-08-2012, 02:23 PM
BillyCuth's Avatar
BillyCuth
BillyCuth is offline
It won't be for a bit I am sure, but let me know how it goes - my clutch on my 03 started slipping earlier this year and I think it's starting to get worse. 114k miles on the ODO.
Old 05-08-2012, 04:31 PM
Evasive's Avatar
Evasive
Evasive is offline
Funny you say that because I actually started working on mine already. Not in a big rush to pull the parts off as my clutch won't be here until the end of the week or early next week. Subframe is out and I'm going to replace my LCA bushing while it's out. Dropping the transmission tomorrow.
Old 05-09-2012, 02:02 AM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
FWIW, I envy people with big ol' garages like you. I can barely fit the MINI in my itty bitty coast of CA size garage. I have to back it into the driveway so I have room to get to my tools!
Old 05-12-2012, 08:26 AM
Evasive's Avatar
Evasive
Evasive is offline
My clutch arrived yesterday afternoon and had the transmission and subframe back on by 7. Only problem is, my clutch pedal doesn't catch pressure until it hits the bottom so the slave barely pushes the fork. Did you have to bleed your slave after a clutch install? I did replace my brake lines while it was on jack stands and have not bled the system yet. I know the clutch shares reservoirs with the brakes so I'm thinking it might have affected it. Going to bleed the system today.
Old 05-13-2012, 05:07 PM
Carmichael's Avatar
Carmichael
What you need to do is bleed the slave cylinder with the piston compressed. There's a write up Ryephile did on how to make a slave bleed tool.
Old 05-13-2012, 06:24 PM
Evasive's Avatar
Evasive
Evasive is offline
Yup. I bled it yesterday. Only took about 10min but it seemed to do the trick. Still need to pick up some transmission fluid tomorrow before I start to the car to make sure its all good.
BTW - I expected lining up the transmission on the engine to be more of a fight but it went it after 10min of lining everything up. I found that having the transmission jack lifting the transmission and a hydraulic jack under the engine made it very simple to line them up as I was able to adjust both the transmission and the engine. Might be useful to anyone planning on working on their clutch.
Old 05-14-2012, 10:18 AM
Italian_spider's Avatar
Italian_spider
Italian_spider is offline
Evasive - question for you that has been nagging at me for months... i notice in your pic that your suspension is not still connected to the sub-frame!! how the hell did you get the knuckles free? The last three times i have dropped my sub-frame i had to take the suspension with it.
Quick Reply: Carnage - The aftermath of a TOB gone IED
