Navigation & Audio Bluetooth compatibility list
Old 02-18-2008, 04:37 AM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
I've been reading thru threads about bluetooth and compatibility with the MINI system. Some people had alluded to other people who sync'd phones that wasn't on the http://www.wireless4mini.com/phones.html list. I'd like to make this thread be a list of phones people have found to be compatible with the MINI's factory system. For discussions about bluetooth, or how to sync phones, where to buy phones, aftermarket bluetooth, etc, please let's leave that out of this thread.
nicknbecka's been doing a great job of keeping a list up to date. I've removed my list and replaced it with a link to his list which I found in his signature area.
Bluetooth Phone Compatibility with R55, R56 & R57
All hail nicknbecka for his continued and tireless effort to keep an up-to-date list of this.
Last edited by dominicminicoopers; 07-14-2009 at 08:49 AM. Reason: point to nicknbecka's more up to date list
Old 02-18-2008, 05:00 AM
dominicminicoopers
Oh, I'd like to list phones that work and phones that don't work. I made the mistake of trying to replace my broken Razor V3 (#7 key stuck) with the below two Samsung models, both of which I had a differing degree of frustration.
NO CONNECTION: Samsung Blast
CONNECTION but drops Buetooth randomly: Samsung Katalyst
Old 02-18-2008, 05:16 AM
LOP's Avatar
LOP
LOP is offline
Good--AT&T Tilt (htc)
Nokia 8620
OK=Samsung Blackjack (no phonebook integration however)
Old 02-18-2008, 05:27 AM
COOP310's Avatar
COOP310
COOP310 is offline
To add to the list...
GOOD:
Apple iPhone
AT&T Tilt
Motorola Razor V3
Motorola v325i
Nokia 8620
BAD:
Samsung Blast
Samsung Katalyst
As this list grows, it might be a good Idea to keep it in alphabetical order for quicker reference.
Old 02-18-2008, 06:32 AM
dominicminicoopers
Keep 'em coming I've updated the top list with the new additions
Old 02-18-2008, 07:10 AM
LOP's Avatar
LOP
LOP is offline
OK=Samsung Blackjack II (no phonebook integration)
Old 02-18-2008, 07:47 AM
Minidrivr's Avatar
Minidrivr
Minidrivr is offline
Have about adding a note next to the phones with cradles available, like the Razr v3?
Old 02-18-2008, 08:58 AM
TheBigNewt's Avatar
TheBigNewt
TheBigNewt is offline
Blackberry 8100 Pearl (phonebook integration, sleeve available).
Old 02-19-2008, 12:13 AM
nicknbecka's Avatar
nicknbecka
nicknbecka is offline
Old 02-19-2008, 07:18 AM
Minidrivr's Avatar
Minidrivr
Motorola MotoRazr V3 (phonebook integration, sleeve available)
Old 02-19-2008, 10:39 AM
nycooper's Avatar
nycooper
nycooper is offline
The iphone works flawlessly and now the cradle "eject box" is available from BMW. (BMW part # 84 10 9 182 792). The eject boxes fit into the armrest of the mini and the phones utilize the roof mounted antenna.
Old 02-19-2008, 12:35 PM
TheBigNewt's Avatar
TheBigNewt
For those who get the sleeve from BMW remember that in order to truly connect directly to the car antenna the phone must have an external antenna jack AND the sleeve must have a fitting that plugs into it. Otherwise it supposedly "wirelessly" transmits the signal to the car antenna (whatever that means).
Old 02-19-2008, 01:53 PM
mikeyjaro's Avatar
mikeyjaro
mikeyjaro is offline
Add Nokia N95-3 (North American Version)..
No Address Book Integration though..
Old 02-19-2008, 03:04 PM
Bonk!'s Avatar
Bonk!
Bonk! is offline
Has anyone installed this in their mini?
BTW: The Samsung MM-A900 works good (phonebook integration)
Old 02-19-2008, 06:54 PM
minicounter's Avatar
minicounter
minicounter is offline
Bad
Motorola v555 (will connect and sync numbers, can receive a call, will not hold connection when dialing out)
Old 02-19-2008, 07:02 PM
playtowin's Avatar
playtowin
playtowin is offline
Has anyone tried the Windows Mobile Treos; 700W and 700WX.
How about the Verizon XV6800?
Old 02-19-2008, 09:43 PM
Minidrivr's Avatar
Minidrivr
Originally Posted by minicounter
Bad
Same as the V557 I had.
Bad
Motorola V557 (connects, phonebook transfers, can receive calls, drops bluetooth connection when dialing out)
Old 02-19-2008, 09:44 PM
Minidrivr's Avatar
Minidrivr
Bad
Bad
Motorol V557 (connects, phonebook integration, can receive calls, drops bluetooth connection when dialing out)
Old 02-20-2008, 02:23 PM
ANT818's Avatar
ANT818
ANT818 is offline
Blackberry 7100 works
Old 02-22-2008, 07:06 PM
miniborna's Avatar
miniborna
miniborna is offline
After a lot of time consuming research and phone calls I finally am able to use the Blackberry 8830 to MINI with even phone book transfer. However, you will need a OS 2.2.176 (platform 3.0.0.79) on your BB. Don't think there is a sleeve yet.
Also, I found out that any bluetooth should be compatible (at least the you will be able to make and receive calls if not the phone book transfer). You will need to update the OS on the phone unless it is a really old phone.
Old 02-22-2008, 07:11 PM
xBoXlOvEr's Avatar
xBoXlOvEr
xBoXlOvEr is offline
Nokia E61 (for phone book sync you have to choose the v2 option in protocol of syncing in the (Phone Symbian) Pc Suite Settings).
Samsung SGH-X820 ok, but you can not call from the nav... you have to dial or search the contact in the phone and then dial (I dont know why...)
Old 02-23-2008, 08:01 AM
RJKimbell's Avatar
RJKimbell
RJKimbell is offline
Thanks for all the posts.
This is a ? we have been having as well. It seems that the www.wireless4mini.com list lists older phone models. Anyone see this? My Husbands co. offers 20% Discounts on our service, we will be switching carriers once MY 08 OB Baby arrives. The dealer did let us know that we would have to buy the cradle for the armrest, but if it only works for one type of phone and not ALL what's the point?
Old 02-23-2008, 08:04 AM
Minidrivr's Avatar
Minidrivr
Yes the cradles are specific for each phone.
Old 02-23-2008, 09:42 PM
mr_r56's Avatar
mr_r56
mr_r56 is offline
Nokia N80 works
But... No phonebook integration
Old 02-25-2008, 11:28 AM
Otra's Avatar
Otra
Otra is offline
Was told that my LG VX5300 could be upgraded by Verizon so that it would be compatible. It had better be - perhaps I should give Verizon a call.
Just found this from an earlier post on 9/24/07:
Originally Posted by Lateral G
Verizon LG VX5300 works fine so far.
Quick Reply: Navigation & Audio Bluetooth compatibility list
