JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW Pulley Size??
Old 11-27-2007, 06:09 AM
RickyJCW's Avatar
RickyJCW
RickyJCW is offline
JCW Pulley Size??
I guys, I have a JCW and the other day I heard that the JCW pulley itīs not 15%. Someone wrote that the JCW pulley itīs around 11% or 12%. Is that real?. In that case, would you install a 15% pulley or would you go with the 17% pulley. I īm afraid that could damage my car in the future (17%). Did any of you compare the JCW pulley and a 15% pulley. Thanks a lot.
Ricky.
JCW 05, Alta Intercooler, Oil catch can, Air Filter Kit, Short Shifter, GP Remap, Galfer Evolution Brakes, KW V2...
Old 11-27-2007, 07:35 AM
k-huevo's Avatar
k-huevo
k-huevo is offline
You won’t damage your MINI with a 17%, or 19% for that matter. The gains from the JCW 11% to an aftermarket 15% without a designated tune are very small. There is a GP map in your signature; from power output to throttle response it’s a worthwhile program for what you have. I went from the stock pulley, to 15%, to 19%, and down to the 11%; the size of the pulley is not the whole story.
Old 11-27-2007, 07:37 AM
tazio's Avatar
tazio
tazio is offline
I have heard unsubstantiated claims that the diameter of the JCW pulley is approximately a 14.5% reduction from stock.
Old 11-27-2007, 07:44 AM
newbs49's Avatar
newbs49
newbs49 is offline
14.88
Old 11-27-2007, 07:46 AM
Newdl's Avatar
Newdl
Newdl is offline
.001
14.881 it is that .001 that makes it JCW....
Old 11-27-2007, 07:59 AM
ChrisW's Avatar
ChrisW
ChrisW is offline
Originally Posted by newbs49
14.88
This is correct.
Old 11-27-2007, 08:04 AM
k-huevo's Avatar
k-huevo
k-huevo is offline
I’ve put the caliper to all of them, do your own measurements, get enlightened.
Old 11-27-2007, 09:29 AM
tazio's Avatar
tazio
tazio is offline
I am willing to study at the feet of a master such as yourself. Could you enlighten me? What did you determine the JCW pulley reduction(s) to be?
chipbagjohn (02-09-2022)
Old 11-27-2007, 09:35 AM
RickyJCW's Avatar
RickyJCW
RickyJCW is offline
. What I donīt understand is why some people say that the JCW pulley itīs 11% and some others say it is 15%?. Why is that?. What would you recomend me?. I might get the SuperSprint Manifold soon.
Old 11-27-2007, 09:36 AM
eager2own's Avatar
eager2own
eager2own is offline
The gains from the JCW 11% to an aftermarket 15% without a designated tune are very small. There is a GP map in your signature; from power output to throttle response it’s a worthwhile program for what you have. I went from the stock pulley, to 15%, to 19%, and down to the 11% . . .
So I'm guessing he found it to be 11%
Edit - having said that, I'd always heard it was 14.something -- though I've never measured it
Old 11-27-2007, 02:30 PM
///ACS330Ci's Avatar
///ACS330Ci
///ACS330Ci is offline
Care to share your measurements? Not everyone has access to more than the pulley that's actually on their own car.
Old 11-27-2007, 02:45 PM
k-huevo's Avatar
k-huevo
k-huevo is offline
The JCW pulley is 10.9161793% smaller than the standard pulley; stock 2.565 in., JCW 2.285 in. I can imagine how the mistake has been perpetuated because I believed the 14.8% myself until I performed the measurement; that’s why I encourage each of you with an interest to be hands on and measure it. Another JCW SC myth I busted was the supposed difference in water pump drive gearing, I had a tech tell me they were taught there was a difference at the national training center, he still wouldn’t believe it wasn’t true in the face of evidence. I think the drive gear myth started with a marketing pre-release spec sheet originating in Germany, which I have a copy of, and somehow it became a “fact” after production.
Below is a photo of a JCW supercharger on the right and a standard supercharger with a 19% reduction pulley on the left. The original purpose of the photo was to illustrate the same water pump drive gear to pulley rotation ratio at 5, 10, 15, and 20 revolutions, and 20 rotation intervals up to 220. With only a glance it is evident the 19% pulley on the left is more than 4% smaller than the JCW on the right.
Old 11-27-2007, 02:56 PM
dimini's Avatar
dimini
dimini is offline
k-huevo-
So, from your ealier post, are you saying that you've experimented with different pulleys and in the end, returned to the JCW pulley?
Old 11-27-2007, 03:26 PM
///ACS330Ci
Thanks for sharing k-huevo I'll definitely have to do some measuring.
I wonder if the JCW pulley is the same size on all years?
Old 11-27-2007, 05:59 PM
JPMM's Avatar
JPMM
JPMM is offline
thats the big question
Old 11-27-2007, 06:30 PM
CmdrVimes's Avatar
CmdrVimes
CmdrVimes is offline
Stuck in Reverse
All the evidence I have found seems to indicate the size has remained the same. I have taken measurements of multiple JCW pulleys (factory and dealer installed) and they have all been the same. I can't seem to locate my post I made a while ago with the measurements and such, but I'm pretty sure the numbers were either identical or very close to what k-huevo posted.
*EDIT*
Just found the post It's Here.
Old 11-27-2007, 06:33 PM
k-huevo's Avatar
k-huevo
k-huevo is offline
I measured 2003 and 2005 JCW models; those two JCW pulleys were the same size and had the same SC water pump drive gear ratio. Later this evening I’ll measure a late build 2006 stock pulley to compare with the stock 2002 pulley I’m using for the basis, just in case there is a difference from that angle.
Old 11-27-2007, 07:01 PM
cooldaddy's Avatar
cooldaddy
cooldaddy is offline
that seems like pretty interesting info since there are a buzillion threads out there stating (or assuming) that it's 14.something, as result concluding that 15% after-market pulleys are basically the same thing...
Old 11-27-2007, 07:02 PM
ScottRiqui's Avatar
ScottRiqui
ScottRiqui is offline
Have you measures any other manufacturers' reduction pulleys to see how close your measured values agree with their advertised percentages?
Old 11-27-2007, 08:31 PM
k-huevo's Avatar
k-huevo
k-huevo is offline
RickyJCW, from purely an economical and effort standpoint, I recommend keeping the pulley you have. As I said before, the difference in output would be small if going to a 15%.
dimini, I started with a stock size pulley, 15% second, 19% third, and am currently running a JCW supercharger.
ScottRiqui, I’ve measured Alta’s V1 model in 15% and 19% sizes and both were very close to their relative percentage.
I measured the 2006 stock pulley at 2.556 inch, so I may have inverted some numbers for the original pulley size notes or whatever (how about that tech term). This would make the JCW a 10.6025% reduction. Not enough deviation to have optimistically skewed the first result significantly.
Old 11-27-2007, 09:04 PM
Grassroots Garage's Avatar
Grassroots Garage
Grassroots Garage is offline
Nice work K
I have been saying this since I installed one of the first round of JCW kits in early 03? ( me thinks, only a few days after its US release) and measured the pullies and water pump gearing... no one believed me then either. I had a collection of JCW pullies ranging from an early 03 right on up to the latest GP's...they are all the same size.
--Dan
Old 11-27-2007, 09:18 PM
tazio's Avatar
tazio
tazio is offline
Any particular reason you've ended up with the JCW?
Old 11-27-2007, 10:00 PM
cucho's Avatar
cucho
cucho is offline
Ricky.
What is the HP output of the GP map?, and where did you get it?...I have the JCW and wanted to get the GP but I was told that no even the dealership has it
Old 11-27-2007, 10:28 PM
k-huevo's Avatar
k-huevo
k-huevo is offline
tazio, it is a process for me, a continuum, so the JCW supercharger/pulley may not be an end, but it sure fits at the moment. My focus has always been about midrange, trying to eke out a little more from the motor for passing and drives out of corners. Along the way, I’ve seen useable performance come from improving volumetric efficiency and a suitable tune, which can match midrange gains attained via more boost (pulley reductions). The VE component is key, adding an 11% on its own won’t get you there, but having more efficient air movement will, even without reducing pulley size. An 11% will provide a moderate increase in boost and as a benefit will only moderately increase IAT. The right tune is equally important, because the driving experience (for me) is not all about raw acceleration, and I didn’t fully realize it until I lucked into the right flash. There’s no doubt, lots of boost, or increasing displacement will get you further than this conservative approach, but those paths are outside of my financial comfort zone.
Old 11-27-2007, 10:36 PM
tazio's Avatar
tazio
tazio is offline
Word. I like your style, Senor Huevo.
So which flash did you luck into?
Quick Reply: JCW Pulley Size??
