I plan on cleaning the calipers and painting them a nice red color. Then getting some ceramic pads, some ss brake lines & some super blue fluid and I should be good to go. I sure do love Ebay. I now have almost the complete JCW package. lol
IMHO, there are many brake upgrades for the R53 that are better than the R56 "upgrade". better choice of sizes for wheel fitment and much better pad selection at this point. if you are feeling the oem love, then go for it.
i just got a set also. talking to dan from grass roots, they are the same as R53 JCW. the pads are the same. the only difference is the holes on the rotor for the lugs are bigger. i think i'm planning on getting some bushings made to fit the smaller lugs.<---not needed(edited post)
Reason: bushings not needed
stu(pid), i have not done it yet, because i'm la(zy). but i have made a "discovery". i will not be needing to put bushings in the larger lug holes. when doing a brake job on a honda oddysey i noticed that after removing the 2 tiny screws that hold the rotor to the hub, i could (after whacking it with a hammer to free it from the hub) actually move the rotor about 1mm radially in either direction. this means that the lugs (or studs in this case) do not actually hold the rotor in place, it is simply the friction of the rotor/hub mating surface. the wheel squeezes the rotor hard enough to prevent it from moving.
so now, all i need to get is some good pads and i can slap them on there.
