Drivetrain Fyool filtah...
Old Feb 9, 2008 | 05:04 PM
hegira's Avatar
hegira
Fyool filtah...
I've done a number of searches, and so far have come up with bupkis on this.
Has anyone found directions on changing out the fuel filter on our cars(R53)? I've seen references to it, despite the fact that the filter is an integral part of the pump assy.
My '02 just turned 30,000 miles, and it's probably a good idea.
Hegira
Old Feb 9, 2008 | 05:36 PM
Capt_bj's Avatar
Capt_bj
not in Haynes
Haynes doesn't touch it ....
no mention of this as a maintenance item .... nor a procedure to change it.
There is a section on changing the fuel pump .... which is integral with the tank level sensors. Not something I'd be inclined to mess with just for fun.
Of course, if we're not to trust MINI/BMW for the recommendeed oil change interval then surely this should be changed annually.....
Old Feb 9, 2008 | 05:48 PM
hemiheaded18's Avatar
hemiheaded18
The shocker here being it's not serviced. Just like the PCV valve. Some trucks are like this, too. The only filter is a sock around the pump itself.
Old Feb 9, 2008 | 08:13 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
Bently does not touch it either
Old Feb 9, 2008 | 08:30 PM
lkbindustry's Avatar
lkbindustry
You take out your back seats. Then you see 2 black covers, you have to unbolt/take off the one on the passengers side and there it is! Pretty self explanatory after that! Just pop off the cover holding the fuel filter in and install the new one!
Hope that gets you there!
Old Feb 10, 2008 | 04:01 AM
hegira's Avatar
hegira
Thanks. Sounds pretty simple. Have you done it yet?
Old Feb 10, 2008 | 02:13 PM
SRICHS's Avatar
SRICHS
It's not the most enjoyable job. This filter also holds the information for your gas gauge. If your gas gauge is not wrong, the chances of your filter being clogged, is slim and none. This is an entire assembly [lines, gas gauge, and filter] that goes in the vehicle from under the backseats. This is not a cheap part, and there is no service recommended change, unless you notice that the gas gauge is constantly wrong. Both black covers under the rear seats have to be removed, due to the wiring INSIDE the tank for the passenger side filter and gauge assembly.
Old Feb 10, 2008 | 06:18 PM
Longboard110's Avatar
Longboard110
Would you care to go into detail on how to "pop off the cover" without breaking it?
Old Feb 10, 2008 | 11:08 PM
Nitrominis's Avatar
Nitrominis
The covers he is referring will come off with a little forceful nudge. Once you remove them it is fairly straightforward. You may find it easier to have your tank near empty when you do the filter change. Just don't smoke when you are doing it..
The reason the Bentley and Haynes does not cover the filter is because at the time of there writing it was considered a NSP. None serviceable part.
Old Feb 11, 2008 | 02:25 AM
hegira's Avatar
hegira
I found this, which, to me, indicates the filter element can be changed out.
http://www.realoem.com/bmw/showparts...07&hg=16&fg=15
I'm inclined to try changing it, when I've got the time (in short supply these days).
Completely off-topic, some S.O.B./P.O.S. hit my car Sunday morning, right after I posted it for sale. And of course left no note. I think I can buff out most of the damage, but it just pisses me off when people show so little respect for other's property.
Ya know what I mean?
Old Feb 11, 2008 | 05:34 AM
Dave.O's Avatar
Dave.O
Page 020-25 of Bentely Mini Cooper Service Manual. (2 ninches thick)
"The Fuel Filter, located in the fuel tank, is intergrated with the right side fuel tank sensor assembly. No Service or replacement interval is specified for the fuel filter"
Old Feb 11, 2008 | 07:30 AM
HighLife4136's Avatar
HighLife4136
I'll probably give mine a go too here soon. Never changing your fuel filter is like never changing your transmission oil or changing your oil every 15,000 miles or changing your coolant every 4 years or changing your spark plugs every 100,000 miles
Sorry to hear about the bump and run...I had the same happen to me last week...not buffable
Old Feb 11, 2008 | 04:08 PM
Nitrominis's Avatar
Nitrominis
" No Service or replacement interval is specified for the fuel filter"
Yes as I said at the time of its printing.
You can service it now. The filter can be removed from the pump and replaced.
Old Feb 12, 2008 | 05:58 PM
Jhud's Avatar
Jhud
supposedly BMW considers this a "lifetime" part and shouldnt need replaced under normal conditions. ill probably do mine at 100k along with the fuel pump but ill probably upgrade the fuel pump seeing as its only 50$ more than OEM. the filter is supposedly part of the fuel pump which i believe is on the right side ( i could be wrong )
Old Feb 16, 2008 | 07:14 PM
StreetMod's Avatar
StreetMod
I am a technician at European Auto in Whitehouse/Tyler, Tx.
I had to change the fuel filter in a couple of MINI's the other day and thought I would take some pics of the process for you guys.
Here we go....
Old Feb 17, 2008 | 12:43 AM
Ancient Mariner's Avatar
Ancient Mariner
Awesome! Thanks, dude.
Old Feb 17, 2008 | 02:05 PM
hegira's Avatar
hegira
Fyool filtah (Bahston)
Thanks very much. Excellent presentation, great pictures and script!
I bet we'll be seeing an increase in filter sales at the local MINI/BMW dealerships.
Old Feb 17, 2008 | 02:10 PM
CustomAV's Avatar
CustomAV
Can anyone provide a list of the part numbers required for this job so we have a proper parts list of what to get?
I guess I would want to make sure I get all the proper o-rings and gaskets and such as well as the filter. I would rather replace all gaskets to be safe considering that they can't cost that much.
Old Feb 17, 2008 | 04:26 PM
Gromit801's Avatar
Gromit801
Bentley does indeed cover removing the fuel sending units, and thus, getting at the filter. They HIGHLY recommend draining the tank first. Might have to do with volatile fumes, static electricity, BOOM, that kind of thing.
Old Feb 17, 2008 | 06:35 PM
jimz68's Avatar
jimz68
As shown above:
Key #2
Part # 16146757196
Element kit comes with o-rings.
Great write-up and thanks for the photos.
One other caution. Be careful when disconnecting fuel line. There may be a bit of fuel under pressure present.
Jim
Old Feb 18, 2008 | 07:33 AM
Kentiki's Avatar
Kentiki
Excellent How-to, thank you.
But I can still smoke while I do this, right?
Old Feb 18, 2008 | 07:50 AM
jimz68's Avatar
jimz68
Oh Yeah!! And you might want to light a few candles for extra light, too.
Jim
Old Feb 18, 2008 | 08:00 AM
chaincoopers's Avatar
chaincoopers
Out of curiosity, how many miles were on that MINI with the filter looking like that?
Old Feb 18, 2008 | 09:42 AM
ScottRiqui's Avatar
ScottRiqui
Likewise, when you examined the old filter, is that dirt/sludge/particulate accumulation we see, or was the filter simply discoloured?
Old Oct 8, 2008 | 07:57 PM
RatBlast's Avatar
RatBlast
HELP i replaced the filter , put it all back in . turn the key and i hear the pump doing its job..... but the car will not start.
took it apart again to see if its got fuel in the new filter, its full to the top . but it is not going into the fuel line. what did i do wrong ?
got it running.... you need about 1/3 tank of fuel before the pump will circulate the fuel .
