R59 Mud Flaps
Old 02-02-2014, 08:02 AM
TG.'s Avatar
TG.
TG. is offline
Very nice work.
I see so many people hacking things together on their cars that it's refreshing to see someone take the time to do it well
  #27
Old 02-02-2014, 03:04 PM
spiney's Avatar
spiney
spiney is offline
Well, they're on. I'm not completely happy with them, but they look fine.
I put on the new 3M tape from AutoZone:
The flaps come with a number of fasteners, some of which I managed to use and some of which wouldn't fit:
Here's the flap held up to the car, with the wheel removed:
Underneath the sill there's a large plug (poor picture, sorry):
You are supposed to remove this and MINI supplies a big plastic rivet that goes through the flap and into this hole. Because of the reshaping of the sill due to the JCW kit this hole both doesn't line up, and is to far from the flap for the supplied rivet to fit. This is the part that I'm unhappy about. I might try to do something better later, but for now I just left the plug in, and did not fit the rivet.
First step is to peel off the backing from the tape, and push the flap into place. Hold it for a little while to make sure it has stuck before you start on the rest of the installation. The upper two clips are usable, either squeeze them in carefully with slip-joint pliers and some protection on the outer visible edge of the flap, or tap them home with a hammer and a piece of wood or a screwdriver. The kit has clips with threaded holes that you are supposed to slide over the edge of the inner wheelarch liner and use screws to hold them in, but I could not get the liner edge out and so I just lightly screwed directly into the liner for now. The lowest clip doesn't line up at all, so I used a small coarse thread screw and screwed lightly into the leading edge of the sill.
I'm about 75% happy with the installation, but from the outside they look fine:
EDIT: Looking at these pictures again, I realize that I'm going to have to do something to plug the hole at the bottom, or it will trap all sorts of mud. Stay tuned...
  #28
Old 02-03-2014, 06:34 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Great job, think it looks great.
The seam on the flap to the JCW side skirt looks factory. Find a piece of thin plastic to cover over or fill the gap. Adhere it to the fabric mesh ( wheel well material) which you can use little screws, stainless steel screws on. I think that would work.
  #29
Old 03-02-2014, 04:23 PM
spiney's Avatar
spiney
spiney is offline
Covered the gaps today. I'd been struggling to find some black plastic sheet, and spent a bit of time wandering around Lowes yesterday. Found this flashing piece in the roofing department (normally used where vent lines poke through the roof):
It's a good thickness and a nice textured finish. Couple of cuts later I had this:
and a small screw and some clear silicone outdoor caulk and the hole is blocked off:
  #30
Old 03-02-2014, 04:29 PM
spiney's Avatar
spiney
spiney is offline
I also fitted the rear mudflaps too. Much easier. They weren't a perfect fit initially:
but a quick trim:
a couple of extra bits of the 3M body tape:
and they're much better:
I'll get some proper pictures of them on the car when the weather gets a bit better.
  #31
Old 03-03-2014, 06:17 AM
spiney's Avatar
spiney
spiney is offline
Pictures with the flaps on:
Found a decent touchless car wash nearby, so it's looking a lot cleaner than of late!
  #32
Old 03-03-2014, 06:42 AM
Looks great, glad you found that filler piece for the front, keeps the snow and grim from building up in that area. Great DIY mod. +1 on your ingenuity.
  #33
Old 03-15-2014, 01:59 PM
spiney's Avatar
spiney
spiney is offline
Two week update:
The weather has been sufficiently crappy to get an idea of the effectiveness. I think they really help. Here are the sides:
There's plenty of dirt around, but way less splatter and spray as there was last time.
The benefit on the rear is less obvious:
I think the rears have helped keep it a bit cleaner, but it's hard to tell.
  #34
Old 03-15-2014, 02:25 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
ZIPPY "S" is offline
spiney.. Nice job on the mud flaps install.. I would say they are doing a great job of keeping the car clean. Even the back ones imo are helping!
  #35
Old 03-15-2014, 03:01 PM
danjreed's Avatar
danjreed
danjreed is offline
nice work!
  #36
Old 03-17-2014, 07:52 AM
Thanks for the update. Like the testing in real world.
  #37
Old 12-09-2016, 08:02 AM
LORDVDR's Avatar
LORDVDR
LORDVDR is offline
Wow! Hell of a job man. Looks totally OEM.
  #38
Old 12-15-2016, 04:48 PM
MiniRoadstah's Avatar
MiniRoadstah
MiniRoadstah is offline
Excellent work. Really looks like a factory fitment. And those flaps will keep the stuff the tires kick up from directly impacting the paint and lower plastic trim. Win-win.
I ordered a set about 3 weeks ago and are in a box in the boot. Don't have the JCW body kit, so should't be as involved, but not going to attempt install right away. The temperature is dropping through 6 degrees F and our garage isn't insulated. Something I should have done long ago.
Lex2008
How to
47
06-15-2022 06:18 AM
daviday
09-25-2015 01:31 AM
Oilfieldtrash
09-21-2015 09:59 AM
USA-RET
09-08-2015 01:50 PM
08-07-2015 08:02 AM
Quick Reply: R59 Mud Flaps
