R57 Retofit connect/enhanced bluetooth
Hello guys!!
My apologies if this has been asked before.
Im about to pull the trigger on a cooper s cabrio from 2009.
The car is in great condition and it has all the extras. I love it!!
The only thing that bothers me is the lack of audio over bluetooth. i hate cables
The car has bluetooth, a center console usb and aux and sat nav.
The last seven digits of the vin are tx78531 and the radio\bluetooth model is 9229740.
My question is. Can enhanced bluetooth be retrofitted\coded somehow? I dont really care about connected, but the lack of audio over bluetooth would make me think twice, which sucks as im getting a great deal.
have a great day you all and please help me out or point me in the right direction
best regards,
Gilberto
best regards,
Gilberto
Thanks for the answer!
Unfortunately the car does not allow to play audio over bluetooth. Works only for the phone (Calls and so on)
So what I would be interested in doing is retrofiting enhanced bluetooth or adding a third party adapter that would let me play audio over bluetooth.
Any suggestions or comments?
Thanks!
If you have don't have bluetooth option you can buy a cheap MPOW ($16) from amazon and that plugs into your aux in I also purchased a Pac ground isolator which connects between the bluetooth module and the aux (it basically filters out noise)
so as not to get any whir noise from engine etc...option ..press the audio button under speedo...then scroll to aux press button to keep it on aux next hit the little button on the mpow and it makes a sound letting you know you are connected next you go into your phones bluetooth settings and connect to the mpow ..done....you can now play your music bluetooth through your radio.....you can not scroll up or down using steering wheel buttons, that you have to do with phone itself. So for the mare price of say $30 you have bluetooth streaming from your phone and the phone music will still pause when a call comes through and continue after call has stopped.
Cool!
Thanks a lot man!
Its by far the best option I have read so far. I really appreciate.
Still, do you know if its possible to code/retrofit enhanced bluetooth?
Thanks!
The only reason why im interested in getting the enhanced bluetooth coded is having the hability to use the wheel buttons to skip my music
Thanks!
Not for a 2009 model. MINI Connected requires the newer electronics that were upgraded in 2011 model year. MINI Connected is required for bluetooth audio streaming.
Tsippi (01-27-2022)
It has the usb/aux input option but, unfortunately, the USB socket does not deliver enough amperage to charge the phone (Moto X). Nor do I want to get into using an audio cable, as that clutters up/complicates putting the phone into the mount. I have a charger that has a bluetooth receiver and an aux-output. That, also, does not have enough amperage to charge the phone. This certainly has a lot to do with the phone, but I'd love to find a proper way to use bluetooth media playback AND charge it.
It seems supremely short-sighted to have support for Bluetooth phone but not media playback.
I have one on order...
It's supposed to be seamless and sound is apparently excellent.
I will post back here when it arrives.
BTW have your MINI checked out by a 3rd party. We bought our 2010 from a dealer and then had our mechanic look at it. A little bit backwards. It was lower risk because it was a Mini Dealership. They had documented all the inspection details and it had an extended warranty on a used vehicle. But when we spoke with our mechanic on her first checkup they showed some concern as some of the older MINIS have issues. Ours turned out OK but...
Patec® USB Bluetooth Wireless Audio Music Receiver Adapter w/ 3.5mm Stereo Output for Headphones Portable Speakers Home and Car Stereo Systems - Black: Amazon.ca: Cell Phones & Accessories
Kinivo and call it a day. It's 35 bux, but it also has a built in usb port in the lighter adapter as well as a control unit that is mountable and easy to hide the wires.
gar56
11-15-2016 06:41 AM
