R56 Aluminum flakes on VANOS
Any other symptoms with P0012? Is it a Cooper or Cooper S?
888.280.7799 | 6am - 5pm PST
For P0012, I'd suggest checking your timing. I've seen this code with non-s MINI's on the forum resulting in a timing issue. The misfire and that code leads me to think it may be a timing issue. Check post #10 and #11 for more info here: https://www.northamericanmotoring.co...-actuator.html. Definitely diagnose the issue before throwing parts at it. Let us know what you find out.
White smoke is typically an indication of coolant. Inspect for coolant leaks. If it's the thermostat, it typically pools on top of the transmission housing. This tech article can help you track down a coolant leak if needed: http://www.pelicanparts.com/techarti..._Leak_Test.htm.
