R56 Vanos Solenoid Cleaning P0012 Code
Old 04-01-2015, 08:48 PM
greentrees's Avatar
greentrees
greentrees is offline
I have a 2009 Mini Cooper Hardtop R56. A diagnostic code of P0012 came up after the check engine light came on. The light went off by itself after a few days.
It sounds like I need to replace or clean the Vanos Solenoid. What is the best way to clean the Solenoid?
If it is the exhaust solenoid, I believe it is in the front of the car, and easy to get to. I attached photos I found on the internet. I don't know if the intake solenoid is in the photo or not.
Attached Thumbnails Vanos Solenoid Cleaning P0012 Code-vanos-solenoid-1.jpg   Vanos Solenoid Cleaning P0012 Code-vanos-solenoid-location1.jpg
Old 06-21-2020, 05:20 AM
Rob Ellis's Avatar
Rob Ellis
Rob Ellis is offline
Hi did this solve your problem, as ive just replaced both units ans still getting the same problem ?
Old 06-22-2020, 02:11 PM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Did you pull to see if the old gunk clogged up the new ones. You might need to flush the engine and clean up that residue around the head inlet.
Old 06-22-2020, 02:27 PM
Rob Ellis's Avatar
Rob Ellis
i flushed the engine and changed the oil and filter before putting the new ones in, its started to do this like divering like shake after abit now, if you pull off the cable to the solenoid it stops shaking and starts running normal.... its weird lol
kucils69
02-07-2023 08:42 AM
plasticmorph
03-20-2019 05:34 PM
RandyD
05-14-2018 06:43 AM
cblackmar
12-20-2016 09:05 AM
tway
R60 :: Countryman Talk (2010-2015)
08-14-2016 06:08 AM
Quick Reply: R56 Vanos Solenoid Cleaning P0012 Code
