R56 behind the intake manifold
Yes i think this is the one... now on those tube lines, the tech replaced 2 small (not over 5cm) plastic tubes, one of them was pretty soft, the other was soft but not as much.
1. Can i see the part for each tube?
2. Is it normal that these go very soft after long use?
3. What symptoms occur when those two tubes go really soft? Should i have any issues like for eg. smell of petrol from the exhaust or disability to idle then starting the car cold?
Use the pics and compare the parts to whats on your MINI
#1 Vacuum tank 11657560916
http://www.ecstuning.com/Search/SiteSearch/11657560916/
# 2 Pressure converter 11657599547
http://www.ecstuning.com/Search/SiteSearch/11657599547/
#3 Vacuum Pipe
http://www.ecstuning.com/Search/SiteSearch/11657570465/
The vacuum pipe connects to the waster gate then #1 and #2 then on the side of the Vacuum pump. It can get little leaks or cracks in the tube.
ShadyCoop
09-20-2015 08:57 AM
kjd186
09-09-2015 10:02 AM
