R56 PCV Delete + OCC - my intake manifold looks... different...
Hello all. I was looking at possibly undertaking a PCV delete + OCC (still looking at all the relevant threads for- and against-) when it warms up.
However, in all the threads I looked at with pictures showing the PCV hose and delete points, I noticed that the intake manifolds pictured do not look like mine. I am attaching some pics of what mine looks like (I ran outside in sub-zero temps to get the pics!)
In short, the PCV hoses are much different. I had to have the entire manifold replaced when one of these little rubber hoses got weak and collapsed. Under warranty... but still...
Thoughts on why my intake is different than most that I have seen? And how can I do the PCV delete on this one? (or can I even do it?)
Thanks,
-Michael
Thanks,
-Michael
You have the "cold weather manifold installed on your vehicle". On a vehicle with a normal intake the pcv is routed into the intake behind the throttle. In freezing temps the excess moisture freezes the throttle and you have starting and running issues. Luckily for you u have the updates intake which injects the pcv gas into the manifold right before the cylinder and no more freezing throttle issues.
Some guys talked about it here. But were using it for a possible carbon cleaning mod.
https://www.northamericanmotoring.co...seafoam-3.html
Intake Manifold Part # 11614584240
http://www.ecstuning.com/Search/SiteSearch/11614584240/
But used for a TSB on iced throttles. Cold climate.
https://www.northamericanmotoring.co...ilable-15.html
1161551 Replacing intake manifold 44WMINI 0.13
1 11-61-4-584-240 intake manifold: 116010
57301 Iced Throttle 1161551 1.30 0.13 found moisture down by throttle.
Hello,
Just an update, we finally have this hard to find part as the Genuine MINI part has been NLA since 2018.
https://www.ecstuning.com/b-bremmen-...614584240~brp/
Just landed and in stock now for the part above.
ScorpionSkins.com
04-09-2013 11:43 AM
