R55 2009 Clubman S R55 Headlight issue
Hello all,
New to the board, but have been on here a couple of times since I bought my daughter her mini 6 months ago for a graduation present. My recent issue is the driver side headlight is out. I replaced the headlight bulb (Xenstart D1S). However, this didn't fix the problem. I swapped the passenger side bulb with the driver side bulb (known good bulb to verify I didn't get a bad bulb off ebay) and the driver side headlight still won't light. Now, the turn signal and the fog lights work. I checked the fuse panel inside the car, but still not working. Any ideas???? Thanks Dave
Check the plug connection at the headlight for corrosion of a pin damaged. 61132359991
https://www.ecstuning.com/Search/SiteSearch/61132359991/ES2860281/
Accessory Products
08-11-2015 12:37 PM
08-11-2015 12:34 PM
