R55 Time to upgrade
Time to upgrade
so I've been reading A LOT about upgrading my 10 R55. I checked with the MINI dealer and the timing chain and tensioner were replaced last year and I'm ready to start modding. I've spoken with John from battle tuning and have been putting together a parts list. John told me in order to do the stage 2 tune I need an intake and exhaust but from reading here most people say K&N is a waste of money and I'm not interested in spending $400 on an intake. Can I get some opinions on if I need it or not. My plan is to do an exhaust not sure which cat back system to do an intercooler and a tune. I was going to do a DP as well but I need to pass inspection so I think a DP is out. Also if anyone has any feedback on the Borla catback I would appreciate that as well. Thanks guys.
I would do a cone style intake. Be that, JCW, AEM, K&N typhoon, NM, DDMWorks, DOS (if you can find one), pipercross, or even alta, it will allow more volume. With a tune you'll want more volume, and that may mean you'll get warmer air (depending on which intake you choose) but you'll be providing the damanded volume of air. Plus getting a good FMIC, should pretty much erase the extra heat from the intake change.
On a stock car, there is little to no benefit of any other intake. The stock car adjusts for air flow differences, so its really pointless to get an intake for that kind of car set up.
Most people agree that the JCW intake is the best option. AEM and DDM are the only two to use the hood scoop. DOS is the loudest and is still argued to be the most beneficial, but you can only get a used one.
I can't attest to the Borla. And the DP depends on what kind of inspection they do, if its just check the light and OBDII, then your ok. If its a sniffer test, then you might be SOL.
Well I just bought a FMIC and have an appt with a local custom exhaust shop that does good work on Thursday. Still not sure what I'll do for an intake but I'm working closer towards the tune. as for the downpipe I work for a dealership so as long as it passes on the ecu I'm good for inspection.
Cool, I also work at a dealer. I'm a service advisor. So it sound like you should be able to do a down pipe with no problem then. Get the intake that fits your needs the best, then the tune. Once you get the tune, I'd recommend taking to the dyno (if you have one close) and getting the tune adjusted, eek out every last HP you can.
I know JM Turbo Coopers developing an exhaust for a clubman and they were looking for a car to do test fitting. If you are close to AZ, it may be worth checking with them. This is what I am planning to get for mine once they have something built. I agree that JCW kit intake (with cone filter) is the one to get, but is hard to find in used condition.
For the R55 Cooper S and JCW (N14 engine ) its a quick swap.
We have ran it on a factory JCW N14 engine and it a direct bolt on with the tube filter. Fits the N14 Cooper S engine also, as its part of the JCW tuning kit.
I would recommend the little gasket also , as the 2007+ R56 Cooper S and The Factory JCW N14 airbox uses the factory panel filter as a seal. otherwise it might rattle a bit. John Cooper Works Tuning Kit Intake does not come with that gasket seal.
John Cooper Works Tuning Kit Intake part # 13720429380
http://www.ecstuning.com/Search/SiteSearch/13720429380/
John Cooper Works Tuning Kit - Air Box With Tube Filter - Gasket Part # 13530433064
http://www.ecstuning.com/Search/SiteSearch/13530433064/
If you want to change to a light oil foam filter , Pipercross has direct fit tube filter.
Performance Foam Air Filter - JCW PX1875
http://www.ecstuning.com/Search/SiteSearch/PX1875/
And here is the cleaner kit for pipercross.
ES#2626400
Pipercross Filter Cleaning Kit
http://www.ecstuning.com/Search/SiteSearch/ES2626400/
ES#2626400
ES#2626400
ES#2626400
So I got to the intake today. It's being installed as we speak. Intercooler will be here tomorrow. I received bad news though. John from battle/DNA tuning is no longer offering tuning for our cars. He said it will be at least a year before he offers it again. I am now in search of another tuning option. Does anyone have any recommendations? Also what are the thoughts on the AP tuner? Is there a list of mods needed for each stage of the AP tunes?
Not bad for our 1.6L
Yeah maybe a hi flow cat will work. Check out my Manic Thread on the drivetrain forums. And look on Manic Motorsports USA on Facebook. I want all you guys to be happy. It's really a whole different car. I'm at close to 260whp now.
Vendor
for a downpipe check out the Akrapovic DP, they are a piece of art. They always fit perfect and have a high flow 100 cell cat. It's what I have for my GP, and highly recommend them.
So I found a local guy who has experience tuning minis but he's saying that he will have to pull the ecu to tune my car because There was a software update that blocks tuning by the OBDii port. I have a 2010 N14 motor and this contradicts everything I have read about tuning this car. He said he would try and do the tune by plugging in but doubts it will work. What do you guys think?
well he said he's reflashed 07s and 08s but has had to pull the ecu on the later cars. I just like the idea of having a local tuner. I just can't be without my car for 3 days.
