R50/53 Spark Plug/Wire/Coil Pack Suggestion
Old 02-02-2016, 08:22 AM
442rick's Avatar
442rick
442rick is offline
Originally Posted by Unbreakable Lump
Unless your car is misfiring, a new coil pack will do exactly zero for you. The solution to that expensive Mini OE coil pack is to buy a Dodge Neon or PT Cruiser coil pack, like this:
http://www.partsgeek.com/gbproducts/...ad=47433965532
Good to know Prof. Lump. You were in on the engine design so we know this will work just fine. A great pleasure it was to read your posts on the engine build.
  #27
Old 03-30-2016, 07:29 PM
Sprague54's Avatar
Sprague54
Sprague54 is offline
Is it possible or is there any draw back from using 1 step colder spark plugs in a stock r53? Looking to do a tune up to the car but still running the stock supercharger pulley. May upgrade in future which is why i want to put the 1 step colder spark plugs the car now. Just not sure when the pulley will be changed.
  #28
Old 03-30-2016, 08:10 PM
Gremothra's Avatar
Gremothra
Gremothra is offline
Originally Posted by Mike87
Highly suggest Magnecor wires, stick with the stock coil pack and use NGK plugs.
I second this.
I've had one MSD die on me and replaced a second MSD with the OEM one, because my Mini kept stalling when it got hot. No problems since going back to the OEM.
Grem....
  #29
Old 03-30-2016, 08:16 PM
quikmni's Avatar
quikmni
quikmni is offline
A colder plug on stock can cause problems, such as engine miss. I have not tried it on a Mini so maybe OK but I have seen problems with too cold a plug on other engines.
  #30
Old 03-31-2016, 08:35 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
It may be best to run the stock plugs until you get your pulley.
888.280.7799 | 6am - 5pm PST
  #31
Old 05-01-2016, 08:11 AM
Andrew Riley's Avatar
Andrew Riley
Andrew Riley is offline
Anyone have any experience with THESE WIRES? I'm at 100k miles and I think it's about time for some new plugs and wires, plus these come in a variety of colors, gnarly! My cars not misfiring, just doing some preventative maintenance.
As far as those $200 wires go... That's a bit insane!
  #32
Old 05-01-2016, 08:26 AM
quikmni's Avatar
quikmni
quikmni is offline
Those are good wires and a good choice if you want to add a little color to the engine compartment. Otherwise, if you just want black new OEM wires are fine.
  #33
Old 05-01-2016, 09:03 AM
CRC's Avatar
CRC
CRC is offline
I have a new set of Beru plug wires listed in the Marketplace. $23.00, inc shipping.
  #34
Old 05-01-2016, 09:09 AM
Andrew Riley
Nice. Looks like I'll be going with those to compliment my red ALTA CAI that's otw along with the NGK BKR8EIX irrdium plugs. Should be a nice n easy little tune up next weekend.
  #35
Old 12-21-2016, 08:18 AM
mij's Avatar
mij
mij is offline
hi, im also looking for the ignition kit, im going to get the Out Motoring Stage 3 Ignition Kit. as they have some options to chose, so i want some suggestions for the kit.
PLUG wire options:
Kingsborne: Red, Blue, Black or Yellow -
MSD: Red -
Nology: Red, Blue, Yellow, Blue
Coil Pack Options -
MSD (red)
Screamin Deamon Coil Pack (shown)
Plug Options:
Beru Ultra X
NGK Irridium IX
Denso Irridium
Brisk LGS
The coilpack i will chose Screamin Deamon Coil Pack, so just want some ideas for wire and plug. thanks!
  #36
Old 12-21-2016, 08:37 AM
quikmni's Avatar
quikmni
quikmni is offline
Kingsborne wires and NGK plugs.
  #37
Old 12-28-2016, 02:01 AM
JaseinHK's Avatar
JaseinHK
JaseinHK is offline
IF your coil pack needs replacing, BERU makes one which is identical to the factory, but has the gold/brass terminals which don't rust and you won't have any fitment issues as the holes and OEM hardware to mount it is all the same.
For those those that put dielectric grease on contacts - DON'T, it's not what it's for. You put dielectric grease on boots/sparkplug body to seal against moisture/air getting inside to the contacts and also to insulate against wayward spark getting out. It should go no where near any electrical contacts as it prevents conductivity.
DIELECTRIC = INSULATOR
https://en.wikipedia.org/wiki/Dielectric
For plugs, NGK EQUP or BRISK LGS-T - no problems with them fouling up and long lifespan.
mynamesconnor
09-18-2017 09:48 AM
davidbeaver1
04-26-2017 05:27 PM
papawhiskey
Electrical
12
03-20-2017 06:06 PM
pauldixoninohio
11-14-2015 02:44 PM
2nsane
11-13-2015 09:52 AM
Quick Reply: R50/53 Spark Plug/Wire/Coil Pack Suggestion
