R50/53 Window Shudder
Window Shudder
Yes, I've searched...
2004 MCS
Lately, when it's hot outside and I roll the windows up, they will shudder, judder, shake, jerk, whateveryouwanttocallit. They still raise, but not without some negative feedback - and really only during the middle of the raising cycle, not the beginning or end. Both doors/windows, only when hot.
It doesn't seem like the regulators are bad, the guides may just need lubrication... somewhere. But I'm loath to start squirting lube in the channels hoping for a miracle. If any of you have had this problem, where did you apply the lubrication?
2004 MCS
You are correct in not squirting lube down the window channels, what you need to do is lubricate the guild rails, this will require you to pull off the door panels.
Here is an example, the part marked in green...
...and of course if that doesn't sort it out, then it is most likely the motors are starting to go bad ...
Motor on!
Motor on!
Motor on!
Motor on!
This works perfectly to smooth out the window-up function.
Do try to lube the rubber edges/window seals....some shops have what looks like a jumbo Chapstick that they run around the windows channels .....it also helps to prevent sticking in the winter when water freeze...that way the windows don't get stick UP ...really important with Windows that dip.....
semibreve42
10-02-2015 09:06 AM
