R50/53 R53 OEM roof rack
Old 05-04-2015, 09:42 AM
jarman65's Avatar
jarman65
jarman65 is offline
R53 OEM roof rack
Hey all,
I'm looking to add a roof rack and cargo bag to my 2005 r53 for a move to California this summer. I've done some research and it seems like the OEM rack is a pretty cost efficient way to go. Does anyone have any idea where I can buy the kit? So far all of the places I've checked are saying it's no longer available.
I'm also not completely closed off to other options as long as they are around $150. I'm on a pretty tight budget.
Thanks!
Old 05-04-2015, 01:17 PM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
The factory kits is NLA for the full kit thats you have to install into the roof. Only the base bars, and some other items are available.
82710024992 just the base bars ( which means you would already have to have the mounted part installed already).
http://www.ecstuning.com/Search/SiteSearch/82710024992/
There is the little known long base system kit here:
https://www.northamericanmotoring.co...roof-rack.html
51130151282 Roof Rack Base - Long Mount System
http://www.ecstuning.com/Search/SiteSearch/51130151282/
and
82710151283 Cross Member Set - Long Mount System
http://www.ecstuning.com/Search/SiteSearch/82710151283/
keyhole saw 83310141898
http://www.ecstuning.com/Search/SiteSearch/83310141898/
and
Test arbor 82790140429
http://www.ecstuning.com/Search/SiteSearch/82790140429/
The bonding agent and primer looks to be NLA. But I bet its Betalink or something close to the window sealing stuff.
http://www.ecstuning.com/Search/SiteSearch/Betalink/
Thanks , that all the info I have on this old kit.
Old 05-04-2015, 01:27 PM
tsprayfhs's Avatar
tsprayfhs
tsprayfhs is offline
Have you considered towing a small trailer? I've towed thousands of miles over 13 years with no problems. Motor on
Old 05-04-2015, 03:03 PM
gpwpat's Avatar
gpwpat
gpwpat is offline
That is what I would do. Get the curt trailer hitch off amazon. It is less than $150. Then rent a small uhaul.
That said. I have the factory roof rack and it is very handy. I have hauled doors, lumber, jeep bumpers, tires and wheels, the factory roof rack has the highest weight rating. But you do have to drill holes in your roof. You dont need betalink sealant. I used black silicone and it is fine.
Old 05-04-2015, 06:29 PM
jarman65's Avatar
jarman65
jarman65 is offline
I would definitely buy the factory rack if they still made the install kit. All i can find is just the bars. My only other option is some used Yakimas since brand new ones are way out of my price range. Theres a good chance I'm not gonna need to use them for a long time so I'll probably just sell them after the cross country trip.
Any idea how expensive it would be to rent a small uhaul one way from Virginia to California? And how difficult is that Curt hitch to install?
Old 05-04-2015, 06:51 PM
gpwpat's Avatar
gpwpat
gpwpat is offline
The hitch install is very easy. Pull off back bumper and it bolts right in using existing bolts. For trailer lights they make a harness that is plug and play in the tailight plugs. Like a 15 min install. Look it up on YouTube there is an install video. Uhaul website should be able to get you a quote. I rented a tow dolly once one way interstate for $90.
Old 05-04-2015, 09:39 PM
FatherG's Avatar
FatherG
FatherG is offline
What is the cost to UPS Ground what you want to get out here vs. rack cost or trailer rent? Plus the hassle of unpacking & packing each time you leave the car out overnite. Things to consider.
Old 05-04-2015, 10:23 PM
spingq's Avatar
spingq
spingq is offline
when I installed my R50 roof rack it didn't come with all those extremely useful installation parts (hole saw, alignment template and arbor gauge) so I had to do it blind, based off measurements in the instructions. I would not recommend this method, even if you are somehow able to get the mounting bolts needed to install the base bars. Although, I'm sure you could find a PDF of the install templates online, which are the most important part of the full kit. You can get your own hole saw, and the arbor gauge is really only used to check the depth of the hole so you don't screw the mounting bolts down too tight and dent the roof - this can be managed by just being extra cautious. Sealant is sealant - you could use silicone sealant, or like ECS mentioned, BMW's favorite goo, Betalink. So, realistically, if you were to source those mounting bolts (8 stainless steel bolts with female threaded inserts through the top and 8 galvanized security screws that attach the base bars to the mounting bolts) you'd be fine ordering just the base bars. I can tell you, it is amazing what you can carry with a MINI on those roof racks - I used to haul 30 to 50 board/feet of hardwood lumber on a consistent basis and it was honestly easier than even a large pickup truck would be. The OEM bars are extremely solid and if you've got a decent set of open ended ratchet straps, you can pretty much safely carry anything.
Old 11-05-2015, 12:21 PM
ssphaneuf's Avatar
ssphaneuf
ssphaneuf is offline
jarman65 they do sell the kit. it's just a pain in the *** to get. I just bought one, it took 6 months to arrive. and i believe that only 4 were shipped to the us. I know this isn't much help but i went to kinkos and made a copy of the templates if you do get your hands on the kit.
Old 11-05-2015, 12:59 PM
They just came back from the dead. These were NLA and now someone at MINI must have pushed to have these made again.
82710024992KT Roof Rack Base Bars Full Kit
https://www.ecstuning.com/Search/Sit...82710024992KT/
And the install kits ( for people that have the bars but need to mount them ) for the white caps are available. 82790139366 . We are waiting for the same kit only with black caps to be released again.
https://www.ecstuning.com/Search/SiteSearch/82790139366/
You can get the black caps here. So just get the above kit and 4 black caps. 82790140913
https://www.ecstuning.com/Search/SiteSearch/82790140913/
Old 11-05-2015, 01:25 PM
beken's Avatar
beken
beken is offline
One of the members of a local club has the mount kit without the bars available.
http://sizeminiclub.freeforums.org/m...-wht-t615.html
Old 11-08-2015, 07:24 AM
inkspot1967's Avatar
inkspot1967
inkspot1967 is offline
do you know where i can just get the black strips that go across the bars? im in need of just those.
Old 11-09-2015, 06:53 AM
The Gen 1 Roof Rack strips are NLA 82790141186
https://www.ecstuning.com/Search/SiteSearch/82790141186/
But you could try the Gen 2 version , i don't know if they would fit but they are made by the same manufacturer. 82720144045
https://www.ecstuning.com/Search/SiteSearch/82720144045/ES2674996/
Old 11-09-2015, 10:49 AM
inkspot1967
Ordered them now thx I will try them out
Old 11-09-2015, 05:17 PM
gpwpat's Avatar
gpwpat
gpwpat is offline
The rack strips are awful. They cause so much noise almost all owners of one roof rack have removed them.
Old 11-13-2015, 01:34 PM
inkspot1967
I ordered the gen2 strips that esctuning listed for my gen1 rack and they fit perfect. Thx esctuning
Old 11-13-2015, 01:36 PM
Awesome thanks
1chaos52
08-24-2015 01:28 PM
Accessory Products
08-13-2015 12:48 PM
08-13-2015 12:47 PM
08-12-2015 01:24 PM
08-07-2015 08:02 AM
Quick Reply: R50/53 R53 OEM roof rack
