R50/53 R53 Loud Fan Noise
R53 Loud Fan Noise
Hi Everyone!
I'm having a weird fan noise when I engage the A/C. It comes on shortly after the engagement and turns off after the A/C is turned off. I tried to listen to the power steering fan and I'm uncertain of whether or not it's coming from there. It sounds loudest behind the radiator.
Here is a video I found that shows the same noise (starts the noise at around 11 seconds):
I've seen people say that it is the power steering fan (which I am pretty sure it is coming from up higher in the engine bay) or some A/C compressor fan. Hoping someone here could guide me through some of the diagnostics of this problem.
Thanks!
Thanks!
That does sound to me like the power steering fan. Depending on your driving and ambient temps, this may or may not be an issue.
I ran into a problem with my fan coming on frequently last summer after even just moderate driving, but especially after stop-and-go city driving. It ended up that I had a failed thermostat housing -- a common failing apparently. I had the thermostat replaced and so far the situation seems to be resolved.
I agree, it's definitely your radiator cooling fan on high speed. I had the same issue with my fan not working on low speed, but worked on high.
