Navigation & Audio Upgraded Speakers
Old 10-15-2014, 04:18 PM
traildog's Avatar
traildog
traildog is offline
Upgraded Speakers
I did a search, but, didn't really get the answer I was looking for.
Is there a "plug and play" speaker for the Mini that is better than the stock ones? I'm looking for more mid to bass tones.....
Old 10-19-2014, 06:11 PM
Fizzyx's Avatar
Fizzyx
Fizzyx is offline
Not sure what you mean by plug and play... There are many aftermarket speakers that are better than stock but you will rarely get their full performance unless you upgrade the other components in the system at the same time.
Old 10-19-2014, 06:34 PM
traildog's Avatar
traildog
traildog is offline
I'm just looking for something that fits in the factory holes that will give a little better performance.
Old 10-19-2014, 06:57 PM
AudioNToxication's Avatar
AudioNToxication
AudioNToxication is offline
Would adding a sub in the boot be an option? I run a JL Stealthbox and love it. I thought I was going to change out all the speakers........ 8yrs later still haven't. Yes it eats some of the boot space but it's not bad. I think i have a picture in my garage thing on here.
Old 10-19-2014, 08:44 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
One tip...
The stock head has fairly low power....
So pay close attention to the efficiency or db per watts the speakers you choose put out, or you may find the system is too quiet with the new speakers....
If I recall, the stock spears are NOT a stock size, but a common euro size...crutchfield has ones that fit or adaptors I believe to let others fit.
Old 10-20-2014, 09:05 AM
Fizzyx's Avatar
Fizzyx
Fizzyx is offline
Ok few things:
1) To make more bass you have to move more air. You can do this by increasing the diameter and/or by increasing the throw of the speaker cone.
2) Both of these will add mass to the moving assembly which, all things equal, require more power to drive.
3) Like Zippy said, factory decks usually lack power.
4) Also, factory decks tend to lack frequency response as well.
So... If you simply drop in a beefier speaker (midbass door), you probably wont be happy with the results.
If it were me, I would start with a new deck and a decent set of 6.5" efficient components speakers. Here's a review of some for ideas: http://caraudionow.com/4997/best-6-5...speakers-2014/
The factory door speakers are 5.25" so 6.5"s will give you a step up in diameter and an aftermarket deck will give you more power and better sound across the whole spectrum. I don't use the rear 5x7"s because I never have people in the back seat.
If that does not give you enough bass then you can look at adding a dedicated subwoofer section to the system.
molala
10-02-2015 01:53 PM
Filmy
09-07-2015 08:27 PM
09-03-2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
09-02-2015 08:17 AM
09-01-2015 04:39 PM
Quick Reply: Navigation & Audio Upgraded Speakers
