Interior/Exterior R56 MCS grill removal
-Bonnet grill:
-Open bonnet
-remove 4 screws
-release handfull of tabs from the bonnet
-remove grill
lower grill:
-pull out 4 plastic snaps along top edge
-pull hard directly forward while holding the bottom edge of grill
reach behind and push in the plastic hinged looking tabs to allow them to fish through the holes in the bumper
-pull off.
-Open bonnet
-remove 4 screws
-remove grill
lower grill:
-pull off.
Aaron@OutMotoring "info@outmotoring.com"
865-223-6335
OutMotoring.com: Home of the finest MINI and Aston Martin Parts + Accessories.
Shop online at www.OutMotoring.com
Free Shipping on most orders over $195 Click HERE
865-223-6335
-Bonnet grill:
-Open bonnet
-remove 4 screws
-remove grill
lower grill:
-pull off.
-Open bonnet
-remove 4 screws
-remove grill
lower grill:
-pull off.
just push them back a little so the snaps release from the bonnet..they will all realease as you pull the grill and slowly release the tabs...(make sure the 4 screws are removed first.)
865-223-6335
865-223-6335
gulp, um are those brackets only attached to the grill? Which is only held on by a few plastic snaps? Hella, is this for real? I would be very cautious of this setup....
865-223-6335
865-223-6335
Front Splitter
Solid as a rock!
Thanks for the observations and concerns I was a little worried about that as well, but with the long metal brackets behind them they are solid as a rock with no apparent vibrations. The Hella 500's are extremely light in weight which helps out alot.
i have easily removed the top grill with these instructions, but i couldnt manage to remove the lower grill. i did whatever i can, i nearly spent 1 hour at the garage to figure it out but no way. i also noticed a plug on the left side at the back of the lower grill (maybe a temp sensor or sth. like that , looks like a tiny antenna)
pls help me out!
pls help me out!
I think this might help
Go to the Alta website for the new R56 intercooler and click on the instructions. I think this will help. Good luck
http://www.altaminiperformance.com/p...ed-Intercooler
07-16-2020 12:54 PM
minipopkart
08-13-2015 05:22 AM
