Interior/Exterior front bumper removal
Old 11-19-2016, 02:38 PM
Seaswood's Avatar
Seaswood
Seaswood is offline
MCS 09
Anyone know what the fittings are under the front bumper in the one vid I found they were torx? The front edge underneath hard to see but do not see torx. A small bit is fitted into a larger bit presumably the smaller one should pull out But it doesn't.
Had to quit be fore i destroyed something.
Old 11-19-2016, 05:28 PM
NB Cooper's Avatar
NB Cooper
NB Cooper is offline
Are you talking about the plastic bumper cover?
If so mine is attached along the lower front lip with plastic rivets and two torx screws, one on each side.
Old 11-19-2016, 07:24 PM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Show pix of what you pointing at. Torx are T20. Than you need to unclip the plastic wheel trim to free it from the bumper and there are two plastic rivets. Push on them while having something push on the other direct from the other side. There is another T20 attaching pumber to rad support.
Old 11-20-2016, 03:01 AM
Seaswood's Avatar
Seaswood
Seaswood is offline
The plastic rivets underside of bumper or cover in center three/four of them I think one came off the others just would not budge? & yes tore on each side I was missing one
Old 11-20-2016, 03:37 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Sometimes with the rain amd dirt they do that. Spray some dw40 or similar to get them loose. Otherwise just yank them out on the replace them.
What are you trying to do if you dont mind me asking?
Old 11-20-2016, 07:34 AM
Seaswood's Avatar
Seaswood
Seaswood is offline
Jbasic maintence some rust on end of frame & as one torx was missing the other was halfway out. I need to know how bumper comes off so when I need to get there it is not an issue.
I will try the wd40
Old 11-20-2016, 07:39 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
Old 11-20-2016, 08:32 AM
Seaswood's Avatar
Seaswood
Seaswood is offline
https://www.realoem.com/bmw/enUS/par...&q=51471911992
I am assuming #11 is the correct fitting to go up into bottom of front cover?
Or is it #13 & 12 the torx?
Like working on a Land Rover but different.
Old 11-20-2016, 09:42 AM
Seaswood's Avatar
Seaswood
Seaswood is offline
I thought you could order through realoem?
Old 11-21-2016, 06:16 AM
MiniToBe's Avatar
MiniToBe
MiniToBe is offline
I dont see the numbers on the diagram. you can order from ebay, aliexpress, www.fcpeuro.com for these plastic parts. realoem is to get the part numbers and order from the dealer. the price you see is the actual price of the item without the dealer's markup price.
Old 11-22-2016, 04:50 PM
Seaswood's Avatar
Seaswood
Seaswood is offline
Thnx got some from local shop but will be good to know.
Went back together a lot easier than it came apart, rust painted missing connectors replaced.
